p72 ecu plug question!
Old May 7, 2002 | 09:32 AM
EKen9's Avatar
Default p72 ecu plug question!
First of all 95 b18c in my 98 hatch. Can someone confirm that this is a 96-98 engine harness? 3 plugs fit in in fine but why wont the green plug fit in the OBDII-I conversion harness? Any ideas?
Old May 7, 2002 | 10:19 AM
boomslang's Avatar
Default Re: p72 ecu plug question! (VTECivic2K)
I don't know what kind of harness that is. Both the 96-98 and 99-00 harnesses use the "A" plug. There is no "A" plug on the harness in the picture.
Old May 7, 2002 | 10:21 AM
boomslang's Avatar
Default Re: p72 ecu plug question! (Inlinefour)
BTW, the OBD2->OBD1 harness you have pictured is for 99-00 Si's and 00-01 GSR's.
Old May 7, 2002 | 10:26 AM
EKen9's Avatar
damnit looks like i have to sell it then. Also what's the "A" plug?
Old May 7, 2002 | 10:52 AM
boomslang's Avatar
The female part of the "A" plug is the first plug in the OBD2 connnector row. (the one you tried to plug the green plug into)
A B C D
Old May 7, 2002 | 10:53 AM
kenji's Avatar
The engine harness you have there is from a '99-'00 automatic transmission Civic. The reason I know this is due to the wire colors and their position. Also, the automatic '99-'00 Civic engine harnesses used the 'D' plug.
The 'A' plug on the '99-'00 Civic is integrated in the interior harness and is not on the engine harness.
That OBD2 to OBD1 ECU conversion harness is one that I made a couple of years ago. It is for a '99-'00 Civic or a '00-'01 Integra.
I am happy to see that my harnesses will be around for a long time changing hands from user to user.
If you have any more questions just ask.
-kenji
Old May 7, 2002 | 11:05 AM
EKen9's Avatar
Default Re: p72 ecu plug question! (kenji)
Thanks for the help but does this mean I cant use either things???
Old May 7, 2002 | 11:09 AM
kenji's Avatar
You are correct. Both the engine harness and the OBD2 to OBD1 ECU conversion harness can not be used in your situation.
-kenji
Old May 7, 2002 | 11:17 AM
EKen9's Avatar
Great that just made my day........
Old May 7, 2002 | 12:56 PM
J_SpeC_EK's Avatar
damn, man.. tough break.. let me know if i can help in anyway.. pz..
Old May 7, 2002 | 02:57 PM
darkknightwong's Avatar
All you got to do now is get a 99-00 SI Harness and your ready to go.
Then you can keep your OB2->OB1 Adapter..
I seen them for around 150
DK
carlos8
Feb 24, 2017 11:28 AM
Shay Cothran
14
Oct 10, 2015 03:16 AM
sonic47
13
Feb 10, 2010 03:23 AM
RyanA
Jan 20, 2007 08:08 AM
Visionist
Jun 9, 2006 11:18 AM
