Synthetic oil
Old Nov 7, 2006 | 05:04 PM
ultimatecivictyper's Avatar
Default Synthetic oil
IS SYNTHETIC OIL GOOD FOR THE HONDA ENGINE AT 80 THOUSAND MILES OR SHOULD I GO FOR REGULAR OIL?
Old Nov 7, 2006 | 05:09 PM
Eran's Avatar
HT White Ops
OH MY GROD CAPS LOCK.
*ahem*
You can keep using dino oil, it'll be just fine.
Padawan's Avatar
Darth ModerVader
Default Re: Synthetic oil (ultimatecivictyper)
Conventional oil at the recommended change intervals is perfectly sufficient.
Old Nov 7, 2006 | 06:33 PM
di2ferio's Avatar
Default Re: Synthetic oil (Padawan)
just use regular oil
Old Nov 7, 2006 | 06:37 PM
EG2Driver's Avatar
Default Re: Synthetic oil (di2Ferio)
its a Honda, plus its a D. You will not see any gains in using syntec, just losses because you'll be wasting your money.
Old Nov 7, 2006 | 06:46 PM
teknoracing's Avatar
Default Re: Synthetic oil (DeadEnd9009)
Keep regular oil changes and stay dino oil. No need to upgrade now.
Old Nov 7, 2006 | 07:00 PM
EX-T's Avatar
Default Re: Synthetic oil (teknoracing)
I boosted my car at 125k and started using Mobil1 at this point for a couple reasons....
1) Synthetic is all the turbo has ever seen
2) I saw the difference in cleanliness of the engine after running synthetic oil (I got the oil pan from the guy who sold me the kit)
3) Synthetic oil can withstand higher temps for an extended amount of time without significant breakdown...
For the OP, I wouldn't change oils if you car is relatively stock....
Old Nov 7, 2006 | 07:08 PM
EG2Driver's Avatar
Default Re: Synthetic oil (EX-T)
for turbo apps, you MUST use syntec if you want it to last. An econo engine simply does not need that kind of lubrication unless ur trying to drive ur car to a milllion miles.
FitsMe
Honda Fit
Apr 16, 2012 05:05 AM
Under_Pressure
Apr 27, 2005 01:41 PM
return_2020
11
Jan 5, 2005 05:42 AM
ironballz
May 13, 2004 02:38 PM
blkbeast
May 28, 2003 10:48 PM
