i wanna make more power
Old Nov 7, 2006 | 04:35 PM
vteckyle's Avatar
Default i wanna make more power
i have intake and exhaust but what else can i do to make more power thanks in advance boys
Old Nov 7, 2006 | 04:38 PM
JDM KID 510's Avatar
Default Re: i wanna make more power (vteckyle)
Depend what you looking for. All motor or Turbo? Is their money issue?
What kind of car? engine? more detail bro.
Old Nov 7, 2006 | 04:40 PM
vteckyle's Avatar
Default Re: i wanna make more power (JDM Kid 510)
its a d16y5 vtec-e and i wanna go all motor
What your HP goal?
Old Nov 7, 2006 | 04:41 PM
Eran's Avatar
HT White Ops
You're starting with a really poor motor and head combonation for all-motor. Swap it out.
Old Nov 7, 2006 | 04:42 PM
deadline's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">You're starting with a really poor motor and head combonation for all-motor. Swap it out.</TD></TR></TABLE>
Old Nov 7, 2006 | 04:55 PM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vteckyle &raquo;</TD></TR><TR><TD CLASS="quote">i have intake and exhaust but what else can i do to make more power thanks in advance boys</TD></TR></TABLE>
This thread was reported as a possible problem. I am going to leave it open but I want to warn you that threads like this are potential victims of the most serious flames and disinformation.
Be careful.
Posters, please be patient with a new user and try to offer legitimate help instead of unmercifully flaming.
Old Nov 7, 2006 | 04:57 PM
hatch96y7's Avatar
Default Re: i wanna make more power (George Knighton)
the leaf blower works i seen a video
Old Nov 7, 2006 | 04:59 PM
eghatch16's Avatar
Default Re: i wanna make more power (hatch96y7)
all motor is too expensive... if you want power the cheapest way is either nos or turbo... id go turbo.
Old Nov 7, 2006 | 05:02 PM
Eran's Avatar
HT White Ops
Honnestly, all-motor would be a very poor choice for your current setup. While your motor does respond well to economy turbo builds (ie good gas milage, and moderately good power). The way your motor works is not like a traditional VTEC motor. Your car runs normally on 3-valves-per-cylinder, but when your VTEC engages, it puts the 4th valve into operation, esentially turning it into a fully functioning Y7 or Y8 before VTEC.
Your best bet for all motor on a reasonable budget would be to build a poor-man's type r:
https://honda-tech.com/zerothread?id=1783523
Anyhoo, enjoy your stay, and learn as much as you can. Also, read the stickies, and try to find information before asking others to find it for you.
Old Nov 7, 2006 | 05:59 PM
dafuzzbudd's Avatar
Default Re: (Eran)
if you REALLY want an all motor you will
1.) spend a lot of money on the build
2.) still be slower than anyone with a turbo on thier big wheel
all-motor seems to go against the grind of the honda motor
if you still really want all-motor after donig your research... you need a b series
Old Nov 7, 2006 | 06:18 PM
jay_cue's Avatar
Default Re: (dafuzzbudd)
bense has a thread on his d15z1 build. lots of good information. slightly different motor, but vtec-e
https://honda-tech.com/zerothread?id=1670633
Old Nov 7, 2006 | 06:32 PM
NSfit's Avatar
Default Re: (whal3_p3nis)
hey if you wanna keep it some what cheap and don't want to hassle with a turbo or a swap i would suggest simple bolt ons like a intake manifold throttle body a nice header, may be take out the A/C. ignition system. you can also gain a little power by keeping your oil clean change your plugs and plug wires. you know the common things. if your interested you may go with a bigger cam and adjustable gear. but in the long run it depends what your budget is.
pulpdeem
Feb 14, 2006 05:34 AM
tommy.
Aug 28, 2005 12:20 PM
Ralpho
Oct 13, 2004 04:46 PM
Boostage
Sep 15, 2004 01:18 PM
Spade
32
Sep 5, 2003 12:34 PM
