Timing Belt Issue??
Old Nov 7, 2006 | 11:08 AM
ek_chris's Avatar
Default Timing Belt Issue??
Okay well, my car one day coming off the hwy.. started to run like ****, the whole chassis was shaking.
Now.. after a weekend of diagnosising I couldn't really find the problem, I was pretty confused.. did a compression test.. to my wonders cyl 1 read 125, cyl 3 read 140psi, or something around there. Needless to say I was baffled (it just read 180psi a month ago) I immediately thought my timing was way off. So I took off the timing belt cover and VC to check the cam gears if they skipped a tooth. I set them both to UP (which btw looked like they were off 1/2 a tooth), so I look down at the crank pulley marks and what do I see?
Looks like its at 8-10 degrees when it should be at the white mark (0BTDC). Now I'm just looking for final confirmation. Did my TB skip a few teeth or what? I'm 99.9% sure but its always nice to confirm these things before I do a tear down.
p.s. I hope I bent a valve maybe this is a sign that a b20vtec is on the way:evil:
actually on second thought, i hope I didn't bend a valve lol
Old Nov 7, 2006 | 02:30 PM
ek_chris's Avatar
The more I think about it, the more I don't want to admit it, but I really think it bent a valve. Compression should still be the same at 10degrees off, atleast I assume
Old Nov 7, 2006 | 03:02 PM
drumking15's Avatar
if you bent a valve...youd be gettin low compresison numbers and it idle really lumpy
Old Nov 7, 2006 | 07:25 PM
distortionexile's Avatar
well i have a really stupid problem.. my timming belt broke and when i was trying to get the stupid thing off i realized i need to get a air hammer to get the bolt off of the lower cam.. but i used a 300lbs compresser and a $1200 gun to make sure it would come off but it doesnt budge i think the screw and the bolt melted together cuz with 250 psi on it< it should either breaks off or come off... got any seggestions?
Modified by distortionexile at 7:45 PM 11/10/2006
Old Nov 7, 2006 | 08:47 PM
02 accord's Avatar
Default Re: (distortionexile)
I don't get it now. First, it was a $1200 compressor pushing 300lb at 250 psi, now it's a 300lb compressor pushing 250 psi and a $1200 gun. What's next?
Old Nov 8, 2006 | 02:45 AM
drumking15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by distortionexile &raquo;</TD></TR><TR><TD CLASS="quote">well i have a really stupid problem.. my timming belt broke and when i was trying to get the stupid thing off i realized i need to get a air hammer to get the bolt off of the lower cam.. but i used a 300lbs compresser and a $1200 gun to make sure it would come off but it doesnt budge i think the screw and the bolt melted together cuz with 250 psi on it&lt; it should either brake off or come off... got any seggestions?</TD></TR></TABLE>
1st off its called a Main Crank Pulley....or MCP for short...and forget all you dam $1000's of air tools...go get the honda-tool from snapon for like $50....2 1/2" ratchets and a pipe extension....then go to town
ps....to brake is to stop or slow down....to break is to destroy something....newbs
Old Nov 8, 2006 | 03:22 AM
NJIN BUILDR's Avatar
Default Re: Timing Belt Issue?? (ek_chris)
Reset your cam timing and see if it cures the problem..duh..
If you have adjustable gears check if they have moved.Your compression can be low if the cam timing is off.
Old Nov 8, 2006 | 12:39 PM
ek_chris's Avatar
Default Re: (02 accord)
thanks for hi-jacking dickwad.
Either way, I don't think I bent my valves after talking with a tech he said my compression would be a lot lower than 130psi if i had a bent valve. Either way I'll be doing the TB and tensioner whenever my damn crank holder tool comes in the mail
Old Nov 8, 2006 | 04:14 PM
hahahaha k w/e the hell the name is i found the tool i need now i just need to buy it ANY DONATIONS??? lol j/k
Old Nov 8, 2006 | 04:54 PM
02 accord's Avatar
Default Re: (ek_chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_chris &raquo;</TD></TR><TR><TD CLASS="quote">thanks for hi-jacking dickwad.</TD></TR></TABLE>
Anytime. FIY, it was distortionexile who hi-jacked your thread. I was just pointing out the inconsistencies in his posts.
Old Nov 8, 2006 | 07:26 PM
ek_chris's Avatar
I meant to click on his reply tab. My bad dude.
gravity73
Feb 9, 2014 03:05 PM
EM1Guru
18
Feb 13, 2010 04:02 PM
Seedc2
Mar 22, 2005 04:53 PM
crxgsr91
30
Dec 10, 2004 11:12 AM
mtber
Aug 24, 2004 06:50 PM
