extreamly noob question
Old Nov 6, 2006 | 06:20 PM
gsr1289's Avatar
Default extreamly noob question
im prolly gonna get flamed for asking this but please try to keep it to a minimum. whats a dizzy? i feel like such a douche for even asking this. oh and then why would i have to disconnect it to do a compression test?
thanks
Old Nov 6, 2006 | 06:23 PM
Padawan's Avatar
Darth ModerVader
Default Re: extreamly noob question (gsr1289)
It's a nickname for a distributor.
Old Nov 6, 2006 | 06:27 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I don't think you need to disconnect the distributor to do a compression test, since the plugs and wires are already removed anyway. But you do need to remove the EFI fuse so that the fuel injectors won't spray fuel into the cylinders and flood the engine.
Old Nov 6, 2006 | 06:28 PM
iheartintegras's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I don't think you need to disconnect the distributor to do a compression test, since the plugs and wires are already removed anyway. But you do need to remove the EFI fuse so that the fuel injectors won't spray fuel into the cylinders and flood the engine.</TD></TR></TABLE>
What he said, you don't need to remove it.
Old Nov 6, 2006 | 06:32 PM
gsr1289's Avatar
wow that wasnt so bad thanks guys. okay so i did a compression test b4 in my autotech class and we couldnt find the efi fuse but we did pull out the ecu fuse and then took the spark plugs out. did the test and i got 125psi across the board and then did a wet test and it shot up to 150psi so my rings are worn which sucks.
Old Nov 6, 2006 | 08:21 PM
GSRteggy00's Avatar
are you supposed to do WOT when doing compression test?? that's what i heard so i just wanna make sure
Old Nov 6, 2006 | 09:15 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (GSRteggy00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRteggy00 &raquo;</TD></TR><TR><TD CLASS="quote">are you supposed to do WOT when doing compression test?? that's what i heard so i just wanna make sure</TD></TR></TABLE>
Yes you are. When I do a comp test I pull the 15A fuse for the injectors.
njmad
Mar 25, 2010 05:35 PM
EM1VtecSi
Aug 14, 2004 11:06 AM
PearlWhiteAccord
Jan 15, 2004 01:49 PM
ownedbyvtec
Oct 4, 2003 09:56 PM
spettinger
23
Dec 5, 2002 02:02 PM
