how to ground coil for compression test?
need to run a compression test before i change the timing belt, would be nice to see what kind of shape the rings/headgasket are in as that would be the best time to pull the head. thanks.
Re: how to ground coil for compression test? (B18C-EJ1)
NO, do not do that.
Remove the ECU fuse, or remove the ECU itself.
DO NOT just unplug the dist. You'll still dump fuel in the holes.
Unplugging the distributor from the engine harness, and pulling the fuel pump fuse (or unplugging the pump from the car harness) is an ASE approved method for disabling fuel and ignition for engine work.
Re: how to ground coil for compression test? (House of Boost)
another method if your lazy like me. This is how I do it:
Basically you leave the keys out of the car (thus fuel and spark are disabled). These two alligator clips clip to the big power wire on the starter and also the thin wire. Pull the trigger and the car is cranking. You could bypass the trigger by using any ordinary piece of wire and shorting the thick power wire on the thin one.
[Modified by Slurp56, 10:52 PM 12/4/2002]
Re: how to ground coil for compression test? (wreckedhatch)
all you really need to do is take the spark plug wires off, and take the plugs out...
turn it over 7 times each cylinder.... make sure its the same number of cranks per cylinder....
Re: how to ground coil for compression test? (pornstarSR)
umm yeah...ok so why would you fry the coil......
so what about the fuel there is so little goin into the engine that its not going to cause a problem....just dont crank it over 30 times
This is what sets us ASE guys apart from you shade tree guys. It's what also seperates the hardcore race cars from the body kit trailer queens.
Re: how to ground coil for compression test? (Slurp56)
So what does that make me? I dont do it the ASE way, nor do I have spark or fuel
Re: how to ground coil for compression test? (hanson said)
wouldn't the fuel going in affect the compression numbers slighty as well?
It could. So could valve timing, the condition of the starter and battery, temperature of the engine, ect ect ect... Best way to determine what's going on in there is a leakdown.
sure if thats what you say, you can do that and im not saying it wont do what you want....
the man that taught me everything and is right next to me is an ASE certified and ASE Master certified mechanic and has worked at honda for 10 years, so i take his knowledge pretty seriously....
dont insult my intelligence as a mechanic....you dont know me.
i dont know you and im not insulting you
[Modified by pornstarSR, 1:29 AM 12/5/2002]
Why not just take the extra two seconds and be safe? This is what sets us ASE guys apart from you shade tree guys. It's what also seperates the hardcore race cars from the body kit trailer queens.
ok i take it back, sorry about that having a few bad days....
plus i get frustrated when people on this board get on there highhorse about things and tell everyone else there wrong (not saying you were doing that)
everyone has there own ways of doing things....weither or not they are the most efficient way of doing it or not it doepends on the purpose and the person....
and when it boils down to it im gona shut up because all the ways you all are stating including mine are ways of doing it that will work...
the way you suggested to do it is the "flat rate way" when time is money
but if its your own car take the extra minute to do it properly
Re: how to ground coil for compression test? (Steady)
Properly. hmmm ok i give up on these people.
you get the same outcome, the same end result, it may not be as accurate, it may not be as clean....but thats not what he asked.
well if you want it to be down to the exact psi then yeah do it your way...
why am i justifying myself
are you just looking for someone to say your right.....
EG-SIXV-TEC
10-02-2011 01:19 PM
