steering wheel shakes while driving
Old Nov 6, 2006 | 02:06 PM
dc2gsr96's Avatar
Default steering wheel shakes while driving
well heres my problem, my steering wheel shakes while driving. i had my lower ball joint and tire rod end off a few month ago and the boots got ripped a little bit could they of went bad that fast. another thing i think it could be is my wheel bearing.. any other ideas??
Old Nov 6, 2006 | 02:10 PM
730_Si's Avatar
Default Re: steering wheel shakes while driving (dc2gsr96)
check your tire pressure in the front tires. low tire pressure can cause a vibration in the steering wheel.
Old Nov 6, 2006 | 05:55 PM
ckyguy's Avatar
did you make sure the tie rod end was put back on to the EXACT place/threads it was before you took it off?
Old Nov 6, 2006 | 06:31 PM
BlueR's Avatar
get an alignment
you "toe" settings are out of spec
Old Nov 6, 2006 | 08:26 PM
99DCteG's Avatar
Default Re: steering wheel shakes while driving (BlueR)
yea what he said... if it shakes only when you press the brake it might be warped rotors.
ChocolateThunda
Mar 5, 2015 01:49 AM
99civ
Suspension & Brakes
31
Nov 6, 2012 09:41 PM
pbizzlegsr
Mar 7, 2007 06:19 PM
nxstrikerxn
Feb 26, 2005 06:29 PM
CereaLand
Feb 12, 2003 08:26 PM
