LSD or not?
Old Nov 6, 2006 | 01:27 PM
trrbl1bmx's Avatar
Default LSD or not?
Can someone tell me the best way to find out if my tranny is indeed an LSD. I had my car in the air the other day, and started it, and put it in 1st gear. I got out and my right front was spinning, and left front was not, so I put my hand on the right front and stopped it, and the left front started spinning. Right next to the H22A stamped code, there is a tag on the tranny with some #'s on it. Do those #'s decifer anything about the tranny or what! Thanks!
Old Nov 6, 2006 | 02:10 PM
hongqun's Avatar
Default Re: LSD or not? (p00n)
not lsd
Old Nov 6, 2006 | 02:14 PM
Fiero's Avatar
Sounds like you don't have a LSD. To be sure, put the car up on jacks (in 1st gear) and have a buddy spin one wheel forward. If the other wheel (the one you're watching) spins backwards freely you have an open diff. If it is just a bitch to move you probably have an LSD - to be sure put the car in neutral, if spinning one wheel forward makes both spin forward you have an LSD.
Old Nov 6, 2006 | 02:19 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: LSD or not? (Fiero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fiero &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like you don't have a LSD. To be sure, put the car up on jacks (in 1st gear) and have a buddy spin one wheel forward. If the other wheel (the one you're watching) spins backwards freely you have an open diff. If it is just a bitch to move you probably have an LSD - to be sure put the car in neutral, if spinning one wheel forward makes both spin forward you have an LSD.</TD></TR></TABLE>
INCORRECT. stock itr lsd's make the wheels spin oppsite directions. but, imho, the original poster does not have a lsd.
Old Nov 6, 2006 | 02:20 PM
Bense's Avatar
with my quaife the wheels spin opposite directions.
1 wheel in neighbors lawn, 1 wheel in drive way. dump the clutch at 4k.
wheel in grass just sits there spinning, open diff
wheel in grass spins for a second, wheel on drive starts pulling car forward, LSD
Old Nov 6, 2006 | 02:22 PM
trrbl1bmx's Avatar
haha. I knew that different diff's act differently... but back to my previous statement, can I gain any info about the tranny from the numbers on it? Thanks!
Old Nov 6, 2006 | 02:43 PM
Bense's Avatar
I dunno, I never look at that stuff.
one wheel in grass + dump clutch = less time than deciphering numbers
Old Nov 6, 2006 | 03:18 PM
f20bej1's Avatar
Default Re: (Bense)
yes you can there are #s on my tranny which say starting letters such as t2t4 indicates lsd sir-t tranny 98 to 2001 accord.
Old Nov 6, 2006 | 05:49 PM
trrbl1bmx's Avatar
Default Re: (f20b eg)
#'s on my tranny are. M2A4 1001 983 which is mated to an H22A with #'s 1010908
Old Nov 6, 2006 | 05:52 PM
trrbl1bmx's Avatar
Bense, I'll try your method tomorrow. haha
Old Nov 6, 2006 | 07:42 PM
goldegg's Avatar
Default Re: (p00n)
when i jacked up my oem lsd b16 the wheels spun opposite directions so i figured it was non lsd, then i took out the axles to replace it and there was the bar across so its LSD.
you really notice it in cornering.
Old Nov 6, 2006 | 08:01 PM
H9Omega's Avatar
Default Re: (goldegg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goldegg &raquo;</TD></TR><TR><TD CLASS="quote">when i jacked up my oem lsd b16 the wheels spun opposite directions so i figured it was non lsd, then i took out the axles to replace it and there was the bar across so its LSD.
you really notice it in cornering.</TD></TR></TABLE>
uhh your wrong there. there should not be a bar there if you have an LSD. It should be see through.
Old Nov 6, 2006 | 08:14 PM
f20bej1's Avatar
Default Re: (H9Omega)
acrual the code b2b4 is lsd your is not
Old Nov 7, 2006 | 09:19 AM
trrbl1bmx's Avatar
thanks!
Old Nov 7, 2006 | 09:43 AM
B18C5-EH2's Avatar
Former Moderator
Loved
God damn I hate opening LSD topics because I always know I'll see the old "both wheels spin...blah...blah...blah..." **** when none of that matters.
THE ONLY WAY TO TELL IF YOU HAVE AN LSD IS TO YANK AN AXLE OUT AND LOOK THOUGH THE DIFF - NO PIN = YOU HAVE LSD
I have personally seen an ITR in neutral on a rack have one wheel spin the same direction when you spin the other, and then seen another ITR spin opposite ways. None of that **** matters!
"Both wheels leave black marks, you have LSD"
Wrong again. I can leave two thick black marks with my one wheeler peeler open diff SOHC tranny in my EF, so fuuck that theory.
In closing here's a pic for an explanation of the looking through the diff deal:
If you see a metal bar or diagonal thick pin in that hole you have no LSD - period. The picture above is of a stock ITR LSD diff; hence the cmpletely empty hole there.
Old Nov 7, 2006 | 10:22 AM
Bense's Avatar
Default Re: LSD or not? (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">God damn I hate opening LSD topics because I always know I'll see the old "both wheels spin...blah...blah...blah..." **** when none of that matters.
THE ONLY WAY TO TELL IF YOU HAVE AN LSD IS TO YANK AN AXLE OUT AND LOOK THOUGH THE DIFF - NO PIN = YOU HAVE LSD</TD></TR></TABLE>
OPM LSD's retain the stock diff pin
Old Nov 7, 2006 | 11:01 AM
Heylookits shawn's Avatar
Default Re: LSD or not? (Bense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">
OPM LSD's retain the stock diff pin</TD></TR></TABLE>
no pins on my oem itr lsd, you can see straight through
i thought you were mr tranny guru
Old Nov 7, 2006 | 11:08 AM
Bense's Avatar
Default Re: LSD or not? (Heylookits shawn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heylookits shawn &raquo;</TD></TR><TR><TD CLASS="quote">
i thought you were mr tranny guru </TD></TR></TABLE>
OPM != OEM
Old Nov 7, 2006 | 11:21 AM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">I snapped a few pics before I had to head back into work tonight ( ):
Stock LS Diff
img]http://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEwMzQzNTZzNDEzZGZkMzF5NTQx.jpg[/img]
OPM - Speedo Gear side
OPM - Ring Gear side
img]http://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEwMzQzNzZzNDEzZGZkMzF5NTQx.jpg[/img]
Metal bl0x
img]http://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEwMzQzODZzNDEzZGZkMzF5NTQx.jpg[/img]
img]http://www.we-todd-did-racing.com/wetoddimage.wtdr/wMTEwMzQ1MzZzNDEzZGZkMzF5NTQx.jpg[/img]
From the Top
From the Bottom
- https://honda-tech.com/zerothre...ge=13
Old Nov 7, 2006 | 12:03 PM
B18C5-EH2's Avatar
Former Moderator
Loved
The "LSD" posted above is nothing more than a spider gear shearing insert block like that of Phantom Grip, and it's not a real LSD.
When looking at a real LSD there still won't be a pin.
When looking at a spring loaded diff locker sort-of LSD you'll see a pin and those fat blocks of steel that end up breaking the spider gears.
Old Nov 7, 2006 | 12:21 PM
jdmsiR20's Avatar
whoa two honda guru's going at it
so yeah, there are basically no honda LSD's out there (stock or aftermarket) with a pin going through them?
Old Nov 7, 2006 | 01:25 PM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">If you see a metal bar or diagonal thick pin in that hole you have no LSD - period.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">The "LSD" posted above is nothing more than a spider gear shearing insert block like that of Phantom Grip, and it's not a real LSD.
When looking at a real LSD there still won't be a pin.</TD></TR></TABLE>
I guess the honda helical torque biasing LSD isn't a true LSD either because it's only 1-way.
http://hybrid2.honda-perf.org/tech/lsdinfo.html
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 &raquo;</TD></TR><TR><TD CLASS="quote">so yeah, there are basically no honda LSD's out there (stock or aftermarket) with a pin going through them?</TD></TR></TABLE>
It all depends on the design. Most however do not use a cross shaft.
Old Nov 7, 2006 | 01:36 PM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">I guess the honda helical torque biasing LSD isn't a true LSD either because it's only 1-way. </TD></TR></TABLE>
We can split hairs all day, but the bottom line is that if this guy wants to see if his tranny is LSD or not he needs to yank out the right axle so that he can look though the diff.
Shoving metal plates that lock the spider gears is a makeshift LSD. Sure a Honda helical is a 1 way LSD which isn't like a reconfiguable LSD that can be 1.5 or 2 way, etc. but it's **** tons better than any open diff with metal plates wedged inside. EDIT - I know there's a 18 page topic about how the OPM diffs rule/suck and I'm not trying to argue that point. They might work, but I'd never risk running one in a street car that is daily driven because they will break spider gears eventually if not sooner.
If you can't agree there then I don't know what else to say.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">It all depends on the design. Most however do not use a cross shaft.</TD></TR></TABLE>
I've never seen a true LSD with a shaft running through it, but I'm not saying it's not out there somewhere. for the purpose of this guy trying to see if his Lude tranny has an LSD none of the "jack the car up and spin one wheel" bullshit is going to help him out.
I'm not picking at you Bense - I'm just saying above all else yanking the right axle will tell the guy the gosphel truth.
Modified by B18C5-EH2 at 5:54 PM 11/7/2006
Old Nov 7, 2006 | 01:49 PM
goldegg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H9Omega &raquo;</TD></TR><TR><TD CLASS="quote">
uhh your wrong there. there should not be a bar there if you have an LSD. It should be see through.</TD></TR></TABLE>
well im owned.
Old Nov 7, 2006 | 02:50 PM
OPM != OEM</TD></TR></TABLE>
hah, i figured it was a really bad typo
racerjohn
Sep 20, 2007 07:43 PM
jaydiem_civic
11
Jan 24, 2007 09:31 AM
UK_EG
Feb 20, 2006 08:06 AM
sambam27
Sep 7, 2003 04:28 PM
JSJ EG6
Apr 17, 2003 07:41 AM
