Car making wierd noise!!
Old Nov 6, 2006 | 01:20 PM
vi3tromanc3r's Avatar
Default Car making wierd noise!!
Well heres the case, i was driving today and all of a sudden there was like a grinding noise coming from the front. It doesnt make the noise when i step on the brakes only when my car is moving. Even when the car is off or in neutral it makes the noise. I notice its coming somewhere from the wheels. Does anyone know what the problem might be and how i might get rid of it?
Old Nov 6, 2006 | 01:39 PM
CEMAYHALL's Avatar
Default Re: Car making wierd noise!! (vi3tromanc3r)
Check the inner fender wheel lining... A tab/ screw could have come out! If thats the problem, it will hit/ rub against the tire and make a nasty noise!
Old Nov 6, 2006 | 01:49 PM
FalkenSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vi3tromanc3r &raquo;</TD></TR><TR><TD CLASS="quote">Well heres the case, i was driving today and all of a sudden there was like a grinding noise coming from the front. It doesnt make the noise when i step on the brakes only when my car is moving. Even when the car is off or in neutral it makes the noise. I notice its coming somewhere from the wheels. Does anyone know what the problem might be and how i might get rid of it? </TD></TR></TABLE>
can you describe the "noise" deeply or not?
There can be about 10,000 "noises" coming from the front end only when not braking.
Old Nov 6, 2006 | 02:53 PM
hm iono how to describe the noise, buts its not the fender. its like when my car is rolling and im not gasing it, it makes a wierd grinding noise. im not to clear on how im going to make the noise on this. but im sure its from the wheel area.
Old Nov 7, 2006 | 07:32 AM
pliskin679's Avatar
Default Re: (vi3tromanc3r)
check your car's break pads, Normally if your at a slow roll and hear grinding it mean's there's no more breaks and its to the bare pad. my mom has this problem right now actully and we found out what it was.
Old Nov 7, 2006 | 08:01 AM
POE's Avatar
POE
break pads.. Sometimes there can be rocks that cut up behind the dust cover.. or maybe your hearing things, im kiding,but check behind the dust cover of the breaks.
Old Nov 7, 2006 | 08:28 AM
civic minime's Avatar
could be a belt, belt tensioner or pulley
Old Nov 7, 2006 | 08:35 AM
POE's Avatar
POE
open that hood up and start listening to everything. Get a scope that the doctors use..
mechanic's use them also
Old Nov 7, 2006 | 08:43 AM
miahmouse's Avatar
Default Re: (POE)
as above have said, brake pads...
fender liners don't stop scraping when you hit the brakes... belts don't make any noise if the engine isn't running, nor do they grind for that matter
Old Nov 7, 2006 | 08:46 AM
POE's Avatar
POE
serioiusly man, take off the wheels and look and see if u got a rock in your break cover.. happens alot.
Old Nov 7, 2006 | 09:36 AM
drtysohc's Avatar
Default Re: (POE)
your brake pads need to be replaced, and since its making a grinding noise...you probably should go get a new set of rotors too.
Old Nov 7, 2006 | 09:53 AM
B16B_coupe's Avatar
HRD PKR
Default Re: (drtysohc)
prob the brake pads or something with the motor. or evern the backing plate
Old Nov 9, 2006 | 02:45 PM
Default Re: (ek9bmxer)
nvm found out wut it was, just somehow my wheel was coming loose. and 3 out of the 4 lugnuts were loose. iono how they started loosening themselves but yea i tighten them and now no more sound.
Si_eg6
13
Aug 28, 2008 05:35 PM
citrus3000psi
Jun 7, 2005 10:37 AM
