5 Lug conversion
Old Nov 5, 2006 | 09:09 PM
671ITR's Avatar
Default 5 Lug conversion
I have a 1994 Integra RS Coupe, and Im going to install a JDM 5 Lug w/ axles.
Is there anything else I need for this conversion?
Old Nov 5, 2006 | 10:32 PM
allmotorabe's Avatar
Default Re: 5 Lug conversion (671ITR)
you don't need the axles you use all your stuff u just need the spindle
you need the rims
Old Nov 5, 2006 | 10:33 PM
Shawn C's Avatar
In The Garage
he will need axles because it's the JDM 36mm itr hubs
you need everything you need. whats your parts list??? lol
EDIT-
parts needed (you don't HAVE to get all of this, but they are the best parts to get, IMO) :
front spindles with full brake assemblies, axles, rear trailing arms with full brake assemblies, and e-brake cables if you don't already have rear disc (which you do)
and this was probably a total waste, because he may never look at this thread again...
Old Nov 5, 2006 | 10:39 PM
Default Re: (Captain Fantastic)
my friend and i did a itr swap and the axles are the same we did not change suspention
Old Nov 5, 2006 | 11:31 PM
671ITR's Avatar
Thanks guys, I made a mistake on the parts, the spindles are 32 spline, will this bolt on directly to my Teg. I have the 15" ITR Gunmetals. Do I have to change anything else?
Old Nov 6, 2006 | 04:46 AM
migs's Avatar
Default Re: (671ITR)
Direct bolt on.
Old Nov 6, 2006 | 06:13 AM
94rs-turbo's Avatar
rubber brake lines thats about it and get an alignment asap!
Old Nov 6, 2006 | 01:39 PM
671ITR's Avatar
So I can still use the stock brake booster and master cylinder?
Old Nov 6, 2006 | 02:56 PM
SilverDc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 671ITR &raquo;</TD></TR><TR><TD CLASS="quote">So I can still use the stock brake booster and master cylinder? </TD></TR></TABLE>
yea, and the brake lines are the same, just upgrade to stainless ones, and get some good pads.
Old Nov 7, 2006 | 09:32 AM
TypeR#1049's Avatar
IF u dont mind me askn .. how much did u pik up the 5 lug for???
Old Nov 7, 2006 | 12:56 PM
671ITR's Avatar
I got mine for a $1000.00, rotors were resurfaced, calipers super clean!!!, looks almost brand new, no rust!!!!
Old Nov 7, 2006 | 01:15 PM
SilverDc2's Avatar
good price, i got a used one for 850 rotors were rusted to hell though
Old Nov 7, 2006 | 02:09 PM
2wheelsmoker's Avatar
Default Re: (SilverDc2)
What size are the hub bolts? The ones on the very end that hold in the axle and hub assembly? 36mm? 1 3/16"?
BMRALR
20
Oct 13, 2007 06:57 AM
TA Performance
May 9, 2007 12:46 PM
92b16hatch
Suspension & Brakes
Mar 12, 2007 08:37 PM
jdmjohn02
Jan 11, 2004 07:56 PM
