How to properly adjust the trans cable???
Old Nov 5, 2006 | 07:15 PM
zx9rbart's Avatar
Default How to properly adjust the trans cable???
1991 accord...2.2 auto.
Old Nov 6, 2006 | 07:08 AM
standbackimapro's Avatar
Auto? if its auto you cant adjust it
But manual theres an adjustment type thing on the end of the clutch cable where it connect to the trans, you just adjust it until theres little or no play in the pedal
Old Nov 6, 2006 | 07:20 AM
Stealthman80's Avatar
Default Re: (standbackimapro)
you mean the pressure cable?
Old Nov 6, 2006 | 08:30 AM
zx9rbart's Avatar
Default Re: (Stealthman80)
Whatever you call the cable that runs from the throttle to the trans...i kept loosening it trying to fix a convertor lock up problem i was having and now that its fixed i want to adjust this cable correctly. At 1/8 throttle on the highway the tranny thinks the throttle is closed and unlocks the convertor. If i give it a little more gas it locks right up and i know i have this cable way too loose...thanks
Old Nov 6, 2006 | 08:32 AM
zx9rbart's Avatar
"Auto? if its auto you cant adjust it"
yes you can.
Old Nov 6, 2006 | 08:52 AM
JimBlake's Avatar
Default Re: (zx9rbart)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zx9rbart &raquo;</TD></TR><TR><TD CLASS="quote">Whatever you call the cable that runs from the throttle to the trans...</TD></TR></TABLE>That would be the kickdown cable. I bet the Helm book has a procedure, but I don't know it. Maybe standback thought you were talking about the shift cable?
Old Nov 6, 2006 | 09:00 AM
zx9rbart's Avatar
Default Re: (JimBlake)
it was late when i first posted and i was afraid the beer in the fridge was going to go bad if i let it sit there...should have been more specific
Old Nov 6, 2006 | 07:08 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zx9rbart &raquo;</TD></TR><TR><TD CLASS="quote">... and i was afraid the beer in the fridge was going to go bad if i let it sit there...</TD></TR></TABLE>Dang! I was in Akron earlier sunday, I coulda helped you out with that...
Old Nov 7, 2006 | 09:27 AM
hondadude's Avatar
Default Re: How to properly adjust the trans cable??? (zx9rbart)
put a long screwdriver on the pressure lever at the front of the trans; just as you open the throttle and the RPM starts to rise the pressure lever should move up slightly.
Driving test; get rolling along a flat level road at 25 mph light throttle, then floor the gas pedal, the trans should downshift to first gear.
Repeat the drive at 28 mph, floor the gas pedal, and the trans should drop to 2nd gear.
sunsetway
15
Jan 10, 2020 12:13 PM
WTB AUTO EK
Mar 11, 2013 03:31 PM
jbrokos307
Jan 12, 2010 07:08 AM
civic702
Dec 27, 2004 12:09 PM
DucatiBoy
Feb 2, 2004 05:54 PM
