Need help: Replacing an alxe on a 95 GSR?
Old Nov 5, 2006 | 07:06 PM
95GSRBOI's Avatar
Default Need help: Replacing an axle on a 95 GSR?
I just read a write up on replacing an axle. I just want to know do you have to unbolt the drain plug from the tranny to replace an axle? After pulling the axle out, will the fluid will pouring out? Also, the write I read didn't say anything about pre-loading the bearing? If I have to, what is pre-loading the bearing? I did it before, but forgot how to preload... haha.. Anyways, I have to do my driver axle soon and I just need a few question answer before process can be able to continue. thanks... Also, anyone selling their gsr drvier axle? let me know.. thanks
Old Nov 5, 2006 | 07:53 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: Need help: Replacing an axle on a 95 GSR? (95GSRBOI)
You don't have to drain the oil, or do anything special,
Just take the old one out, and proceed in putting the new one in.
You will need a 32mm socket for the Axle nut though.
Old Nov 5, 2006 | 08:20 PM
95GSRBOI's Avatar
Default Re: Need help: Replacing an axle on a 95 GSR? (CleanLikeJdm)
I know.. thanks for the informations... I have all the tools where I am able to do it with no problem. Just hate to have a stubborn lower ball joint where I have to beat the crap out of it before it come loose. anyone else have good advice before I proceed. thanks
Old Nov 5, 2006 | 09:12 PM
-Darren-'s Avatar
if its the passenger side axle then a little bit of fluid might come out when you pull it out. maybe like a cap full, nothing serious.
Old Nov 5, 2006 | 09:29 PM
davidluko's Avatar
There's a trick on popping the lower ball joint. Let me see if I can find a picture for you.
*edit - here it is: https://honda-tech.com/zerothread?id=887859
Modified by Hatch_R at 11:43 PM 11/5/2006
Old Nov 8, 2006 | 02:46 PM
95GSRBOI's Avatar
Default Re: (Hatch_R)
Thanks, sweet method.
Old Nov 8, 2006 | 05:18 PM
Sam92Teg's Avatar
If you only jack up the side of the car you are working on, the tranny oil will flow to the other side and not out the vacant hole. I use 'the trick' on separating the lower ball joint and a short pry bar to separate the axle from the tranny housing or intermediate shaft. Good luck.
minvi
Aug 9, 2010 04:17 AM
sumrandomazhole
Transmission & Drivetrain
Apr 30, 2010 10:39 PM
lazii_boi08
May 4, 2009 10:34 PM
boardrider
Mar 10, 2006 10:16 AM
DarkCyde SI
14
Apr 22, 2003 04:06 AM
