My tailight wont turn off! Help help help
Old Nov 5, 2006 | 06:51 PM
93blackcivic's Avatar
Default My tailight wont turn off! Help help help
When I turm my car off the tails stay on!
Help!
Battery goes dead.
It is my brake light.
Whats wrong.
Car=94 civic hatch
Old Nov 5, 2006 | 06:58 PM
slambedcivic's Avatar
Default Re: My tailight wont turn off! Help help help (93blackcivic)
brake light switch. ive never replaced one on a honda. but it should be somewhere around the pedal assembly
Old Nov 5, 2006 | 07:00 PM
Thanks man.
I was hoping it wasnt that.
Old Nov 5, 2006 | 07:03 PM
Default Re: (93blackcivic)
why? is it hard to do? i mean, its inside of the car and i cant imagine it being too expensive. could be much worse
Old Nov 5, 2006 | 09:22 PM
onacouch's Avatar
In my old Accord there was a small piece of plastic that fits into a small hole on the metal top part of the brake pedal. Eventually my plastic piece broke. When the brake pedal is at rest the plastic piece pushes in a button, and when the button is pushed in the brake lights stay off. When you push the brake pedal the plastic piece moves off of the button and your lights illuminate. If this piece of plastic breaks (mine shattered some how) your lights will never turn off unless you push the button with your finger.
If you see small pieces of plastic under your pedals then this is probably what has happened. I took the shattered pieces to Honda and they knew what it was before I even said anything. The part that sucked was that it was like 3 bucks for a tiny piece of plastic. If you're crafty enough you might be able to find something else to stick there instead of buying a 3 dollar piece of plastic.
Old Nov 6, 2006 | 04:37 PM
Default Re: My tailight wont turn off! Help help help (onacouch)
That was the problem. The little rubber fell out so I glued it back in and problem resolved.
Thanks guys
93grayeg
19
Sep 8, 2009 07:30 PM
sleepa
Oct 5, 2008 09:22 PM
_dergo_
Aug 4, 2007 12:37 PM
SD94GSR
Apr 30, 2007 02:47 PM
CONLESS
Jun 15, 2005 09:48 PM
