What should i do next?
Right now i have a stock GSR turbo, i'm going to try and push for more power and get better traction, right now im at 333 whp. My problem is i don't know what i should i do next? Traction bar? Drag Radials? Pistons and Rods? Intake Manifold and Type R Cams? My best bet would be all of the above but i don't have that kind of money.
So what should be my next purchase?
which turbo set up are you using? injectors? ECU? etc. If your content with the amount of power you have, then I'd start looking into suspension, or what the others have mentioned...LSD. The limited slip should definately help you with all wheel spin you're probably getting with that much power.
SC 50
Rc 550 Injectors
Inline pro mani
TiAL WG and BOV
p28
NepTuned
I want more power for the most part, but if i get anymore then im sure ill have all kinds of traction problems.
Rc 550 Injectors
Inline pro mani
TiAL WG and BOV
p28
NepTuned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cm zak »</TD></TR><TR><TD CLASS="quote">post ***** you already asked this</TD></TR></TABLE>
I asked what pistons and rods are the best bang for the buck. Now im trying to figure out if i should get those next. Im running like 15 psi or so.
