LCR Bushing Question
Old Nov 5, 2006 | 09:42 AM
DraginTeg93's Avatar
Default LCA Bushing Question
I was reading some where that you can get bushings for the rear lower control arm that dont need to be pressed in once you take the old ones out that you can just put theses in urself no problem . If anyone has heard about theses or were can you buy them at .. thanks
Old Nov 5, 2006 | 09:47 AM
atg1290's Avatar
I know that energy suspension makes them and i had them with the complete set. They work good, just lube up and slide it in there. A hammer is useful jsut incase.
Old Nov 5, 2006 | 09:48 AM
Sam92Teg's Avatar
Default Re: LCA Bushing Question (DraginTeg93)
I used ES bushings that can be pressed in pretty easily, they are a 2-piece design. You can use a long nut and bolt setup with washers to install them. Some have used a 2x4 to stand on to press them in. I personally used an Arbor Press purchased from Northern Tools for $23. They went in like butter, so I am sure these other methods would work also.
Old Nov 5, 2006 | 11:55 AM
dvp's Avatar
dvp
Default Re: LCA Bushing Question (Sam92Teg)
I haven't seen any that don't require a press in of some sort.
GagnarTheUnruly
Suspension & Brakes
Jun 13, 2011 12:35 PM
5.0 Killa
Jan 18, 2009 08:50 AM
RCautoworks
Suspension & Brakes
Apr 2, 2007 08:20 AM
Loserkidwac
Jul 5, 2006 11:57 AM
tthomass
Suspension & Brakes
Jan 17, 2005 05:32 AM
