I need help with my idle...
I have a gsr in my eh9 and its idling funny. It goes to 2000rpm and drops back down to 900rpm.
I just finish rebuilding the motor with type-r internals (pistons,valve springs,cams,and retainers).
The motor has been running fine until now...
Any suggestions would be great. Thank you
fast idle thermo valve? or idle air control valve? im assuming you have an intake on the car, if so, take it off, start teh car, and there should be 2 holes inside of the TB. warm the car up and let it do its idle jumping thing. when it does, cover up on of those holes if it stops doing it. its the fast idle thermo valve. if not, then most likely its the IACV
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redferio »</TD></TR><TR><TD CLASS="quote">thank you.....would it be easier to just change the throtle from a b16 to a gsr</TD></TR></TABLE>
No its an easy fix.
No its an easy fix.
