What needs to be done to an LS to keep up with a GSR?
Old Nov 5, 2006 | 12:37 AM
94CivicRally's Avatar
Default What needs to be done to an LS to keep up with a GSR?
How many mods does it take to get an LS to keep up with and beat a GSR?
Old Nov 5, 2006 | 01:06 AM
97CGPintegra's Avatar
Default Re: What needs to be done to an LS to keep up with a GSR? (94CivicRally)
how many mods? just slap a turbo kit on there (one mod?) and it'll beat a stock gsr.
Old Nov 5, 2006 | 05:36 AM
eg6ajk's Avatar
you're working w/ 30-35whp less, w/ longer gearing and lower redline. cheapest way is boost, as in bolt on kit. Then you not only able to keep up but beat them. if you want to keep it NA, then usual bolt ons, set of cams + SiR/GSR tranny or 4.785 FD w/ ITR/GSR diff. Or do a B20 + mild cams w/ boltons w/ shorter geared tranny. Basically about $1000-2000 in mods and you can run high 14's.
My favourite mods:
1> lightweight flywheel (10-12lbs is perfect for drag and response)
2> 2.5" header + cat and exhaust
3> cold air intake
4>mild cams
CleanLikeJdm's Avatar
Hype-R Stalker
b16/Type-r, Gsr transmission, and you'll have a much better chance of keeping up.
Old Nov 5, 2006 | 08:41 AM
jdm_bones's Avatar
Slap a B16 PR3 head with P30 Pistons on that B18B and the do as the other have already stated Si, Type R or GSR tranny....And you will walk all over them!
Old Nov 5, 2006 | 08:50 AM
projectTeG's Avatar
we need more info. i mean what cars(years) and suck. because i had a 91 RS chassis(with a 93 ls) with I/H and a bit of weight reduction and it would take Gsr's out. my ls was faster not just because of the weight reduction, but also the fact that the 90-91 cars came with a shorter ls tranny with a 4.4FD.
Old Nov 5, 2006 | 10:29 AM
aaronISthrowed's Avatar
Default Re: What needs to be done to an LS to keep up with a GSR? (CleanLikeJdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanLikeJdm &raquo;</TD></TR><TR><TD CLASS="quote">b16/Type-r, Gsr transmission, and you'll have a much better chance of keeping up.</TD></TR></TABLE>
That will make a big difference.
Old Nov 5, 2006 | 11:44 AM
JThrasher79's Avatar
Default Re: What needs to be done to an LS to keep up with a GSR? (aaronISthrowed)
i got a b16 tranny w/ lsd and intake, intake mani, header, exhaust. GSRs with mods cant keep up let alone a stock one. just get a b16 trans and see where your at, youd be suprised..
Old Nov 5, 2006 | 11:51 AM
dvp's Avatar
dvp
Default Re: What needs to be done to an LS to keep up with a GSR? (JThrasher79)
The LS motor is way under rated most opf the time. It's a great motor. Good quality regular bolt on's will get you close. Gearing is deffinately an issue...as already stated.
Old Nov 5, 2006 | 01:42 PM
Leo C's Avatar
Night Owl
Default Re: (projectTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">we need more info. i mean what cars(years) and suck. because i had a 91 RS chassis(with a 93 ls) with I/H and a bit of weight reduction and it would take Gsr's out. my ls was faster not just because of the weight reduction, but also the fact that the 90-91 cars came with a shorter ls tranny with a 4.4FD.</TD></TR></TABLE>
I doubt this.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94CivicRally &raquo;</TD></TR><TR><TD CLASS="quote">How many mods does it take to get an LS to keep up with and beat a GSR?</TD></TR></TABLE>
I almost keep up w/ my friend's bolt-on GSR. Mods are in sig.
Old Nov 5, 2006 | 02:28 PM
dohcMONSTER's Avatar
tranny, tune and good bolt-ons
Old Nov 5, 2006 | 02:52 PM
doood's Avatar
been there done that
Default Re: What needs to be done to an LS to keep up with a GSR? (dohcMONSTER)
spray
Old Nov 5, 2006 | 03:01 PM
Brice.Hayden's Avatar
Default Re: What needs to be done to an LS to keep up with a GSR? (that one doood)
bad *** LS set up
ITR pistons with crower 402 cams, i/h/e
and it'll take out gsr
Old Nov 5, 2006 | 03:02 PM
bad *** LS set up
I know i've seen it...
eg w/gsr i/h/e vs
ef ls w/ls tranny and above set up.
EF won
Old Nov 5, 2006 | 03:23 PM
Schister66's Avatar
Man U FTW
N20 would be the cheapest route....i personally would do an LS/VTEC and boost it, but it really depends on your budget
Old Nov 5, 2006 | 04:08 PM
shawn69's Avatar
is this true?
Old Nov 5, 2006 | 04:37 PM
doood's Avatar
Default Re: (shawn69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shawn69 &raquo;</TD></TR><TR><TD CLASS="quote">
is this true?</TD></TR></TABLE>
it actually has longer gears. but it does have a 4.4 fd.
Old Nov 5, 2006 | 04:43 PM
zeroz's Avatar
Default Re: (that one doood)
bolt ons and maybe b16 tranny with nitrous! easy as that!
Old Nov 6, 2006 | 08:24 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by that one doood &raquo;</TD></TR><TR><TD CLASS="quote">it actually has longer gears. but it does have a 4.4 fd.</TD></TR></TABLE>
has a longer 1-2nd an shorter 3-5th i believe. its a really nice tranny to have.
Old Nov 6, 2006 | 12:19 PM
2ndgentegracer's Avatar
Bolt-ons and a good driver should get you close.
I know my LS beat up on stock GSR's all day at the track. I've pulled a GSR on the freeway too. We'll see what my B20 setup nets.
Old Nov 6, 2006 | 12:25 PM
doood's Avatar
has a longer 1-2nd an shorter 3-5th i believe. its a really nice tranny to have.</TD></TR></TABLE>
after looking for more info, it does have a slightly shorter 3-4
1quickvr4
11
Jul 17, 2005 08:20 AM
H.crx-si
Mar 17, 2005 01:21 PM
dohcnotec
Dec 29, 2003 12:00 PM
xaznx
Mar 13, 2003 10:37 PM
Lenthrax
Sep 9, 2002 06:01 AM
