Passing smog? obd1 b16a, obd2 vehicle.
Old Nov 4, 2006 | 11:09 PM
strictly.business's Avatar
Banned
Default Passing smog? obd1 b16a, obd2 vehicle.
4th time ive tried to get an answer on this.
i know i will need to run an obd2 ecu, anyone have a suggestion as to which one would work the best? currently im using the obd2 harness with alternator and distributor converted to obd1.
what is required and or what needs to be swapped/changed/converted for me to not throw any codes with and obd2 ecu?
its obd2a by the way. thanks.
Old Nov 5, 2006 | 04:08 AM
Duane_in_Japan's Avatar
Default Re: Passing smog? obd1 b16a, obd2 vehicle. (strictly.business)
how about giving your smog numbers.
Old Nov 5, 2006 | 09:40 AM
Banned
Default Re: Passing smog? obd1 b16a, obd2 vehicle. (Duane_in_Japan)
...its obd2? i really think you should re read my post so you can comprehend the problem.
Old Nov 5, 2006 | 04:10 PM
Banned
up.
Old Nov 5, 2006 | 04:13 PM
sicones's Avatar
Default Re: (strictly.business)
you need a delsol OBD2 P30, or a P2T from a 99-00 civic with a OBD2B->A conversion harness
Old Nov 5, 2006 | 05:21 PM
Banned
Default Re: (sicones)
k. i know what ecu's i COULD use, im trying to find the ideal one that will throw the least codes AND i need to know what i will need to change on the motor to not throw a code for examply, oil pump etc.
Old Nov 5, 2006 | 05:38 PM
sicones's Avatar
you put a OBD1 engine in a OBD2 car , now you want to pass emissions, goodluck, those are the only USDM B16 ecus that will let you pass OBD2 emission whether you want to believe it or not.
First question, is the engine JDM?
Old Nov 5, 2006 | 06:45 PM
Banned
obviously if its a b16a.
i know what ecu's i can use, those arent the only ones. im just trying to find the ideal one.
i wish someone who knew what needs to be changed on the motor would post.
flash0124
Engine Management and Tuning
Oct 19, 2012 08:32 PM
Brugalontherocks
Apr 28, 2008 08:10 PM
turbogsr18
Apr 28, 2008 10:37 AM
iluznxpnoi
Mar 30, 2002 11:40 AM
