HELP!!VTEC MALFUNCTION
Old Nov 4, 2006 | 08:02 PM
97eksoldier's Avatar
Default HELP!!VTEC MALFUNCTION
HEY GUYS NEED SOME HELP AGAIN..WELL I FINALLY FINISHED MY MINI ME.BUT THERES A PROBLEM ITS THROWING THE CODE
P1259
VTEC System Malfunction
IM SURE THAT THE WIRING IS CORRECT..DO U GUYS THINK IT COULD BE THE VTEC PRESSURE SWITCH..IF SO HOW DO I CHECK IT OR HOW DO I CHECK TO SEE IF THE SOLENOID IS WORKING ..
ANY HELP IS MORE THAN HIGHLY APPRICIATED GUYS THANK YOU VERY MUCH...
Old Nov 4, 2006 | 08:19 PM
EX-T's Avatar
Default Re: HELP!!VTEC MALFUNCTION (97eksoldier)
First things first...hit the caps lock button...
Second, get a voltmeter and test the solenoid for voltage.
Old Nov 4, 2006 | 08:21 PM
Default Re: HELP!!VTEC MALFUNCTION (EX-T)
yeah figured that about that caps button my bad..but anyways thanks ..how much voltage should the pressure switch, and solenoid read
Old Nov 4, 2006 | 08:24 PM
hondavet's Avatar
Low oil level will give you that code also...
Old Nov 4, 2006 | 08:36 PM
Default Re: HELP!!VTEC MALFUNCTION (hondavet)
even when i erase it.... at key on engine off... it comes back on before i even start the car
Old Nov 6, 2006 | 08:54 AM
does anyone no what the voltage should be at the switch and the solenoid
ToeJam
Apr 3, 2008 06:01 PM
cioli
12
Feb 26, 2006 08:31 AM
HondaFanBoy
Jun 16, 2005 11:25 AM
Sleepin Crx
Aug 11, 2003 09:45 PM
shonnys92si
Jan 20, 2003 11:45 PM
