3rd gear grind. i think i need new synchro set
Old Nov 4, 2006 | 07:20 PM
tekstyle's Avatar
Default 3rd gear grind. i think i need new synchro set
1999 gsr:
at high rpm, 3rd gear grinds when upshifting. heel-toe downshifting is fine, but not smooth. rev matching helps the upshift a little, but not much. will a synchro sleeve set from a 1999-2000 civic si fit my car? parts number is 23623-P21-315. at this site.
https://www.hondapartsdeals.co...M++14
Old Sep 2, 2007 | 11:36 PM
gamakichi77's Avatar
Default Re: 3rd gear grind. i think i need new synchro set (tekstyle)
me also had the same problem. some of my search found the same parts number with you. but some of the search i found is : P/N 23623-P4C-308, H/C 6780811
which one is correct one?
heavy duty
Mar 17, 2010 06:52 AM
turbo-crx
Nov 3, 2008 04:22 PM
n-line4
Oct 11, 2005 03:34 AM
Ehron
12
Mar 29, 2003 02:53 PM
