Grind in 3rd gear. Which parts do I need to fix the synchros? (IMG inside)
Old 03-22-2003, 06:26 AM
Ehron's Avatar
Default Grind in 3rd gear. Which parts do I need to fix the synchros? (IMG inside)
The grind is not consistent yet, but I know I will have to fix it before long.
2000 si transmission.
Old 03-22-2003, 07:59 AM
GReddy SI's Avatar
Default Re: Grind in 3rd gear. Which parts do I need to fix the synchros? (Ehron)
yes i would like to know also ,, but i would need 5th gear also
Old 03-22-2003, 09:08 AM
tvrsir's Avatar
Default Re: Grind in 3rd gear. Which parts do I need to fix the synchros? (GReddy SI)
you need the number 7 set
Old 03-22-2003, 10:08 AM
Ehron's Avatar
Default Re: Grind in 3rd gear. Which parts do I need to fix the synchros? (tvrsir)
So the number 7 set is the whole synchro assembly? I would need all of it just to fix the 3rd gear?
Old 03-22-2003, 10:59 AM
Snail EG's Avatar
you do not need all of it, you only need the syncho gear itself. but you aren't not gonna be able to buy it alone. it only comes in the set like that.
Old 03-23-2003, 04:26 AM
Ehron's Avatar
Default Re: Grind in 3rd gear. Which parts do I need to fix the synchros? (Snail EG)
Alright, cool. Thanks for the info.
Old 03-23-2003, 09:54 AM
turbod16y7vtec's Avatar
how much are the synchro sets? and does anyone know how much it would be to get it done? or can you do it yourself?
Old 03-23-2003, 10:22 AM
t0p_sh0tta's Avatar
Default Re: Grind in 3rd gear. Which parts do I need to fix the synchros? (turbod16y7vtec)
HondaAutomotiveParts.com - They will have prices on the website.
Old 03-23-2003, 10:40 AM
jus f0 dekarayshunZ
ciRcuitJerk's Avatar
depends on where you go ...this is something that i personally would not try alone without someone that knows how to do it...if i had a manal then maybe...dealer charges about a grand to do it...i only got mine done there because i have a warranty
Old 03-23-2003, 10:46 AM
Suprdave's Avatar
Default Re: Grind in 3rd gear. Which parts do I need to fix the synchros? (CiRcUiTsi)
3rd Gear Syncro set is about $200.
Old 03-23-2003, 10:48 AM
be professional
Targa250R's Avatar
Honda put out a technical service bulletin on this a while back. Take it to the dealer and complain - see if they'll fix it for free or with a big discount.
It's TSB #01-082 (October 2001). I used to have a PDF file of the actual document somewhere, but I seem to have misplaced it.
Old 03-23-2003, 05:07 PM
Ehron's Avatar
Default Re: Grind in 3rd gear. Which parts do I need to fix the synchros? (Targa250R)
Great, thanks for the info. I am not sure they would care though since the engine is in a different car. I wonder if that voids technical service bulletins.
Old 03-29-2003, 02:53 PM
Ehron's Avatar
I started driving the car regularly, and I found an easy solution until I can afford all my driveline parts. I just double clutch between 2nd and 3rd. Easy as that.
Hope that helps you guys with transmission woes.
kaj
Transmission & Drivetrain
10-31-2010 07:57 PM
turbo-crx
11-03-2008 04:22 PM
tekstyle
09-02-2007 11:36 PM
RTW DC2R
10-17-2006 07:41 AM
Quick Reply: Grind in 3rd gear. Which parts do I need to fix the synchros? (IMG inside)
