Timing belt
well i bought the timing belt and water pump and got the haynes repair manual but still dont get it i know i have to remove the bottom timing cover but doesnt seem easily i have done many engine swaps before but cant do timing or anything internal any way easy to remove da bottom cover thanks for all your help
Just lower the motor some after you loosen the motor mount on that side and you should see the few bolts holding it on. Be careful when putting everything back to TDC so stuff doesnt hit each other..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtpktz. »</TD></TR><TR><TD CLASS="quote">Doesn't a snapped timing belt = seized motor on interference motors?</TD></TR></TABLE>
no. it means that valves get bent.
Ken Collins
Jun 21, 2013 04:02 AM
Kidloco51
Mar 28, 2005 02:42 PM
