loss of oil?????
Old Nov 4, 2006 | 01:42 PM
dabomb's Avatar
Default loss of oil?????
i have a b18c1 that is drinking oil likes its pay day on a friday and its a buck a beer at the bar!!!!!!!!!!!!!!!!!!!!!!!!!!!!
heres what i have found while trouble shooting.......
no oil leaking externally from the motor.
oil is clean and so is the antifreeze so head gasket is still good.
compression test is 220 psi across the board.
i drove the car for 150 miles and the dip stick went from the full mark to completely dry. i checked it both times when the motor was cold and had sat for atleast a couple of hours. i put 10w30 oil in it.
i was told that i could do a leak down test but it is most likely shot rings rather then a problem in the head.
i tried searching but cośldn't find anything to convincing that its time to do the block up.
let me know what you think boys and girls
thanks
Old Nov 4, 2006 | 04:34 PM
mnaines's Avatar
Default Re: loss of oil????? (dabomb)
Hmm...The only cheap thing I can suggest is to find an oil treatment called "restore" and use it on the next oil change, since that product is designed to reduce oil consumption by improving the seals around the pistons and filling in the small cracks and abrasions inside the cylinder. Its not a permanent fix, but it should help until you find the source of the problem. If you cannot find the source of the problem from any external means, then you may have some serious cracks or abrasions in the walls of the cylinders themselves, which would cause a loss in oil. If that's the case, you would also notice a drop in compression. If it is bad rings or seals, then the costs are usually low, depending on the rings/seals that need to be replaced and whether or not you have to take the entire engine apart just to replace them. It could also be the type of oil you are using...If you use a low-quality oil, then most of the oil is not being consumed, rather it is turning to sludge due to its inability to handle the heat from combustion. I would recommend Castrol or TropArtic oils, SAE Energy Conserving II rating if you can find some.
Old Nov 4, 2006 | 04:39 PM
thesmogman's Avatar
Check your PCV valve. If it's stuck open it will drain it quickly. I loss 1/2 a qt in 50 mi's
Old Nov 4, 2006 | 04:42 PM
mnaines's Avatar
Default Re: loss of oil????? (thesmogman)
When my PCV valve went bad, it started whistling, though I guess I was just lucky. You might also want to check the EGR (exhaust gas recirculation) valve while you're at it.
95_red_dc
Jan 29, 2009 11:37 AM
210jdmgsr
Aug 15, 2007 03:55 PM
silvlude
Jul 31, 2003 05:12 PM
HybridGSR1
Jul 4, 2003 07:37 AM
BoM
Aug 12, 2001 11:23 PM
