JDM FD install woes
Old Nov 4, 2006 | 01:36 PM
43!'s Avatar
43!
Default JDM FD install woes
I installed my 4.7 FD and 1-5 gears are awesome BUT reverse is giving me issues.
The shifter doesn't click into reverse like it should. The car will reverse if I hold the shifter back but the second I let go it crunches out.
Is there any adjustments to be made? I swear if I could pull back reverse a few more cm, it would be ok. My idea is to remove all the linkage and start over to see if that helps. Anyone have any other ideas besides drop the trans?
Old Nov 4, 2006 | 01:52 PM
hayabusa160's Avatar
Default Re: JDM FD install woes (43!)
check your tranny fluid level.
some trans will do that if its low.
chad's Avatar
Moderator
you might have put the reverse pin in upside down or not tightened the 2 10mm bolts that hold the reverse gear
too many possibilities....who installed it
Old Nov 4, 2006 | 01:55 PM
43!'s Avatar
43!
Default Re: JDM FD install woes (chad)
Yours truly
Old Nov 4, 2006 | 02:53 PM
Evs-One's Avatar
Solbros Owns Me
gonna have to pull it apart
look at what Chad said, I've seen a lot of people put the reverse idler gear upside down too!
Old Nov 11, 2006 | 12:03 PM
43!'s Avatar
43!
Default Re: JDM FD install woes (Evs-One)
I got it cracked again and every looks OK. When I pull up slightly on the syncro shaft, it will engage reverse but without doing this, I can't shift it into reverse.
The gear is the correct way as well. All the bolts are tighten down to spec.
When I drove it before, It would drive in reverse if I kept pressure on the shifter. The second pressure wasn't applied, it popped out.
My friend was thinking install the case back on set in reverse to see if that would help.
??? any other ideas?
Old Nov 11, 2006 | 02:24 PM
Bense's Avatar
anyone have pics of b-series handy? mainly the top of the mainshaft?
IIRC, the b-series and d-series differ from each other is this regards.
btw, I love being called into these trans threads with the other tranny guys, what's up tranny guys
Old Nov 11, 2006 | 02:56 PM
chad's Avatar
Moderator
Default Re: (Bense)
no pictures....
yes you will have to hold the shift fork to link everything up to get it to go into reverse with the tranny case off
Old Nov 11, 2006 | 05:02 PM
43!'s Avatar
43!
Default Re: (chad)
I opened it up, didn't see anything wrong. Retighten the bolts to spec and put the case back on and it's all good in my hood now for whatever reason.
Thanks for the advice.
ryan89crx
Aug 23, 2006 08:53 PM
wrx'n you
Dec 21, 2005 08:20 AM
rizq777
Sep 25, 2004 07:57 AM
mojord
13
May 21, 2002 08:08 AM
A-dub5513
Feb 16, 2002 06:47 AM
