misfire problem?
Old Nov 4, 2006 | 11:58 AM
kitong's Avatar
Default misfire problem?
i change the coil on the # 4 cylinder den check the spark plugs which they were all good and reset the ecu, but check engine light still on and had it diagnost again and came out still misfiring ,.. so n e of u guys had the same problem maybe could help meeh fix it?????
Old Nov 6, 2006 | 07:32 PM
SLOW K20's Avatar
What sparks plugs are you running??? might be wrong heat range also if your turboed or supercharged it might be the gap in the plugs...
Old Nov 6, 2006 | 07:48 PM
rawsx's Avatar
Default Re: misfire problem? (kitong)
I have the same problem. Did you have a race header installed recently?
05hondagirl
Honda Civic (2001 - 2005)
Sep 23, 2013 08:46 AM
jdm.fanatic
Sep 26, 2009 05:14 AM
bumbaiulearn
11
Mar 28, 2006 12:49 AM
boosted lude
Oct 10, 2004 12:23 PM
mattymatt
Jun 28, 2001 12:50 PM
