Low Oil pressure??
Old Nov 4, 2006 | 11:47 AM
aznd87's Avatar
Default Low Oil pressure?? wasssup??
heyyy my red light on my cluster for Low Oil pressure just turned on, what does that mean and how do i fix the problem?? please let me know, thanks -Mike
Old Nov 4, 2006 | 01:11 PM
old man neri's Avatar
Default Re: Low Oil pressure?? wasssup?? (aznd87)
Chances are you ran out of oil. Check how much oil you have, oh and don't drive your car anywhere.
Cheers.
Old Nov 4, 2006 | 01:15 PM
aznd87's Avatar
Default Re: Low Oil pressure?? wasssup?? (old man neri)
Thanks man, anyone else got any ideas on this?? what to do, thanks
Old Nov 6, 2006 | 10:49 AM
Hirev's Avatar
Need help. How do I check my oil pressure on a D16Z6 to see if I have enough oil pressure for vtec?
Old Nov 6, 2006 | 10:56 AM
hondaman86's Avatar
if its not low on oil, possibly the oil pressure switch could of gone out.
Old Nov 6, 2006 | 10:58 AM
Max Kling's Avatar
Default Re: Low Oil pressure?? wasssup?? (hondaman86)
Chunks of your bearings are causing flow issues .
Or your oil pump could be going out.
Old Nov 6, 2006 | 11:03 AM
instructor74's Avatar
the red neck way pull the valve cover off start the car if you have oil pressure it will spray oil all over the place. The proper way by the oil filter is your pressure sending unit take it out and thread in a working oil pressure gauge. min oil pressure at idle is around 10psi min oil pressure at 5k (i think its 5k) around 50psi call the deal if you don't know they will tell you the oil pressure and rpms over the phone
Old Nov 6, 2006 | 01:11 PM
Mr Hammond's Avatar
a/k/a Jomo
Well the obvious first thing you should do is check your dipstick and add accordingly.
Old Nov 6, 2006 | 01:32 PM
teknoracing's Avatar
Default Re: Low Oil pressure?? wasssup?? (Mr Hammond)
Yeah, check your oil level first.
Elevorett
10
Jan 2, 2010 06:23 PM
vtec.dc2
Feb 1, 2004 10:49 AM
LSVTECoupe
Aug 30, 2003 08:52 AM
Snafu-Si
Mar 24, 2003 10:47 PM
vti-R
Jan 31, 2002 05:06 AM
