opinions on nitrous
Old Nov 4, 2006 | 09:41 AM
cleanej2's Avatar
Default opinions on nitrous
my motor is a d15b7 and i was thinkin about adding nitrous for the extra hp but i wasnt sure if it will ruin the motor
Old Nov 4, 2006 | 10:06 AM
f20bej1's Avatar
Default Re: opinions on nitrous (cleanej2)
i run 60hp and i have been running for long time that does not mean it is good
but i have got it tuned for nos
cheapest hp
Old Nov 4, 2006 | 10:11 AM
cleanej2's Avatar
Default Re: opinions on nitrous (f20b eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f20b eg &raquo;</TD></TR><TR><TD CLASS="quote">i run 60hp and i have been running for long time that does not mean it is good
cheapest hp </TD></TR></TABLE>
do u have a wet or dry setup .. n how many miles are on ur motor
Old Nov 4, 2006 | 10:15 AM
f20bej1's Avatar
maybe 39000 on a f20b its dry
Old Nov 4, 2006 | 10:17 AM
cleanej2's Avatar
which setup is safer for the motor
Old Nov 4, 2006 | 10:19 AM
f20bej1's Avatar
people say wet but i used dry
fuel delivery is essential so i say wet
Old Nov 4, 2006 | 10:21 AM
petty$rep's Avatar
wet better than dry b/c a wet kit also injectes extra fuel with another injector that comes with the kit. whereas a dry kit depends of the stock fuel injectors to make up the difference. wet has less of a chance to cause detonation on your motor, also getting your car tuned for nitrous will help with the reliablility factor.
the best setup is a direct port kit
Old Nov 4, 2006 | 10:29 AM
joe_bocc's Avatar
I'm building a D15B with a ZC block. All OEM parts, no rebuild. I'm planning on buying a Zex wet kit with a ~50 shot.
I've got no worries about cooking my motor. Just install the kit properly and use a realistic jet setting and you should be fine. I'm assuming you're only going to use it occationally.
Old Nov 4, 2006 | 10:58 AM
fasthatchb18c1's Avatar
The only reason ppl think Nitrous is dangerous is because they dont know what there doing and spray over and over thinking there motor is not getting hot since the dummy gauge doesn't say so. When I used Nitrous I hooked up a EGT sensor so I could see my exhaust temps. I never had any problems on a stock motor.
Old Nov 4, 2006 | 02:36 PM
crimsonv4mpire's Avatar
if you're motor already burns oil, i'd think twice nitrous devours failing piston rings
Old Nov 4, 2006 | 02:41 PM
fdjizm's Avatar
what a reliable shot for stock internals?
Old Nov 5, 2006 | 11:12 AM
Default Re: (fdjizm)
50-75.. much more is askin for it. if you're tryin to get anything more i'd think about building your motor.
Old Nov 5, 2006 | 11:16 AM
EX2SI's Avatar
Default Re: (crimsonv4mpire)
Id rock it... but for the same price you could do a homemade turbo kit....Just my opinion
Old Nov 5, 2006 | 01:04 PM
Harryflores's Avatar
Default Re: (EX2SI)
get a wet system!
Old Nov 5, 2006 | 01:05 PM
acrocat's Avatar
as long as its tuned right and your careful with your ignition timing and what plugs you use.. you should be good
Old Nov 5, 2006 | 02:05 PM
aaaabbbb's Avatar
Do not purchase anything from me. -HT Staff
Default Re: (acrocat)
i have a nos wet kit for sale pm me if u want it
foowitdaredek
22
Apr 30, 2007 12:43 PM
Beastymanway
11
Jul 24, 2005 11:35 AM
CRXstress
11
Jun 1, 2005 08:20 AM
Gen2Integra
Jan 29, 2004 05:08 PM
StreetRacnGsR
24
Jun 6, 2003 09:11 AM
