how can i fix this??
Old Nov 4, 2006 | 07:00 AM
TomatoRed's Avatar
Default how can i fix this??
my 98 ex is throwing these codes-
P0501- vehicle speed sensor range/performance problem
P0135- primary heated oxygen sensor (sensor 1) heater circuit malfunction
P0141- secondary heated oxygen sensor (sensor 2) heater circuit malfunction
P1298- Electric load detector circuit high voltage
what does this mean and how do i fix it?
thanks in advance!!!
Old Nov 4, 2006 | 07:53 AM
s_vares's Avatar
Default Re: how can i fix this?? (TomatoRed)
Well, thats alot of stuff to just break at one time.
check your VSS plug (located on transmission) for rust and crap, make sure its tight. Check for broken wires to either of the o2 sensors or main harness. The O2's are on the exhaust by the motor with 4 wires on them. Did you have an engine fire? Is this a newly installed motor or tranny? maybe O2 sensor plugs reversed. Good luck, if you provide more info I will try to help more
Steve
Old Nov 4, 2006 | 07:56 AM
Superdragr45's Avatar
Default Re: how can i fix this?? (s_vares)
i encountered this problem before on my 99 EX (well, the o2 problem and the ELD problem). apparently (and just my opinion), the ELD can be shorted out if ur o2 sensor(s) go bad. more than likely, u will have to replace the whole fuse box under the hood and the o2 sensor on the bottom of the header.....................good luck man......
Hairy56
Apr 3, 2016 03:00 AM
lnewman1975
Honda Civic (2001 - 2005)
May 9, 2013 05:06 AM
novtecnoboost
Feb 11, 2007 06:56 PM
johnzm
Jul 7, 2002 05:19 PM
A11MotorR
Jul 7, 2002 08:45 AM
