How to change inner and outter CV joints? 88 crx
Cant search for CV so anyone know a link or can write a quick write up.
What tools specifically will I need.
Whats the easiest method
Best place to buy from for price (and price I should expect to pay)
Anything else I should know.
Replace the axles. Search for axle replacement.
You'll need a 32mm socket. Strong arms.
~65.00 each at Autozone.
-Des!
-Des!
and:
A cheap pry bar is helpful
Ball-joint remover (rent a good one it from autozone)
Couple bottles of transmission fluid
a pan for draining trans fluid when the axle is out
NEW cotter pins for the ball joints
Transmission fluid filler hose kit for refilling (~$5)
So i cant just replace the cv joints...or are you saying it would be alot easier to just replace the axels. cuz cv joint is only 20 bucks at autozone
You can replace just the joints pretty easily, but the boots are a bitch.
Spend the extra coin and get the complete axle from Autozone. It comes with a lifetime warranty so you don't have to buy them again.
DJ:A
Oct 29, 2001 10:03 AM
