Suspension & Brakes Theory, alignment, spring rates....
Rack and pinion overhaul.
Old Nov 1, 2006 | 02:00 PM
DirtyOldTown's Avatar
Default Rack and pinion overhaul.
I'm trying to overhaul the rack and pinion on a '91 DX hatch. I've got the pinion dust seal and the snap-ring out. I can't see anything else holding the pinion/bearing in, but it won't come out. I tried a slide hammer but no luck. Anyone done this before? I've tried everything I can think of short of heating up the case. This thing is giving me a case of the red-***. The service manual just says:
"Remove outer dust seal, pinion dust seal and snap-ring. Remove pinion from steering gear. Slide rack from steering gear."
I'm going to soak it in PB Blaster overnight and try again. Hopefully I don't destroy this thing in the process. It's a $200 car with 300k mi. on it - I'm not trying to break the bank putting parts on this thing. So far all I'm out is a few bucks for a rack end bushing and a pinion seal.
Old Nov 1, 2006 | 02:02 PM
Tyson's Avatar
Default Re: Rack and pinion overhaul. (DirtyOldTown)
outer race is probably siezed to the side of the cylinder. i would bang it a couple more times with a dead blow, or rubber mallet.
you removed the spring tensioner on the back side, right?
Old Nov 1, 2006 | 02:29 PM
Default Re: Rack and pinion overhaul. (Tyson)
Thanks for the quick response. Yeah, the rack piston, spring, etc. have all been removed, as have the tie-rods. I'm going to soak it like I said, and I'll try beating on it some more tomorrow morning when I get back to the shop. If that doesn't work I'll probably just grease the rack up as best I can and roll with it. This thing won't be on the road for a long time anyway, and my other civic works perfect.
Old Nov 2, 2006 | 09:12 AM
Got it out - Soaked it in PB and then beat the case with a brass hammer a few times. I couldn't pull it out by hand but I got it with slide hammer in one swipe. It's back together and working well. The rack end bushing makes a huge difference - took all of the play out of the passenger side of the rack.
Old Nov 2, 2006 | 09:50 AM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DirtyOldTown &raquo;</TD></TR><TR><TD CLASS="quote">The rack end bushing makes a huge difference - took all of the play out of the passenger side of the rack.</TD></TR></TABLE>
...esteban
Jul 19, 2016 09:35 PM
10cjennings
14
Aug 17, 2013 08:50 PM
hypnolobster
Feb 3, 2013 04:32 AM
96hb
Suspension & Brakes
May 1, 2010 10:38 AM
carsaregood
Aug 13, 2003 04:19 AM
