OBD2 and CAT'S
Old May 6, 2002 | 03:53 PM
m0t0rhead's Avatar
Default OBD2 and CAT'S
Is a resistor the only thing that's available to allow an OBD2 Accord to not throw codes with a test pipe ?
I would like to get one but don't want the check engine light
Old May 6, 2002 | 05:25 PM
ArchAngel Sabastian's Avatar
New User
Default Re: OBD2 and CAT'S (Escobar)
oom by "test pipe" i asume you mean a "hollowed cat", or "free flow cat"?
i ran a free flow cat on my 96 obd2 accord and i had the bung from the old cat cut fitted and welded into the freeflow and i never threw a code.
[Modified by Sabastian, 8:26 PM 5/6/2002]
Old May 6, 2002 | 05:27 PM
m0t0rhead's Avatar
Default Re: OBD2 and CAT'S (Sabastian)
wow.... i'm surprised.... is this for rizzo ?
was it a test pipe or high flow cat ?? high flow cat's still have honeycombs..
Old May 6, 2002 | 05:30 PM
urbantrain's Avatar
my testpipe doesnt throw a code, but i have obdi, but my header did *shrug* i think it has to do with my o2 sensor, but how the hell could the ECU know if you have a cat or not? its just a pipe! unless it counts on back pressure or something.. uhm, try hitting it with a hammer
Old May 6, 2002 | 05:33 PM
m0t0rhead's Avatar
Default Re: OBD2 and CAT'S (urbantrain)
_______
OBD2 - Onboard Diag. 2 - has a second O2 after the cat that reads clean air. If it reads dirty (having a test pipe) it raises voltage and throws a code on your ECM.
Then your car won't run right..
[Modified by Escobar, 9:33 PM 5/6/2002]
Old May 6, 2002 | 07:28 PM
New User
i didnt know the difference i see now tho..
yah mine was "honeycombed" thats a good way to explain it lol.
Old May 6, 2002 | 08:26 PM
FastechAccord's Avatar
Actually, if the O2 in the cat throws a code it in no way affects the running of the car. The primary O2 sensor is the one that will make your car run like crap if it throws a code.
Old May 6, 2002 | 08:30 PM
New User
Default Re: OBD2 and CAT'S (EvoAccord)
ACTUALLY, it will.
Old May 7, 2002 | 05:16 AM
m0t0rhead's Avatar
No, it will cause your car to run bad.. I had the O2 go bad on me once, and had to get it replaced. I had to drive the car for 3 days before getting it fixed and I was constantly spitting black smoke out the exhaust and the car ran like crap.
[Modified by Escobar, 9:16 AM 5/7/2002]
EJeff8
18
Aug 20, 2010 11:47 AM
o0oz
Oct 10, 2009 06:27 AM
no2unenolife
Oct 31, 2005 03:08 PM
Electron Si
15
Feb 11, 2004 02:57 PM
Hard2Find
Sep 16, 2002 07:42 AM
