question about h22 swap in 4th gen accord
Old Oct 31, 2006 | 08:47 PM
bigsha2k's Avatar
Default question about h22 swap in 4th gen accord
i have a 92 accord lx automatic and i want to do an h22 swap..but can i keep my original automatic transmission..and keep the same axels....basically i just wanna kno if its possible just to do the engine swap without changing anything else?
Old Nov 1, 2006 | 11:36 AM
accord93_h22's Avatar
Default Re: question about h22 swap in 4th gen accord (bigsha2k)
yes you have to replace the wire harness and ecu also but it can be done.
Old Nov 1, 2006 | 02:53 PM
4rthgencord's Avatar
all you need to do is replace the ecu and add pins to your stock wiring harness for vtec pressure, vtec solenoid and a knock sensor.
no need to replace wiring harness on your car man. other than that is is a complete drop in swap. you will also need an h23 or f22a6 downpipe. it is the 2 hole downpipe. the f22a1 will not work.
hope this helps.
Old Nov 1, 2006 | 04:29 PM
bigsha2k's Avatar
thanx i really appreciate it..so i kno what to look for and not get screwed by the person doiing the swap!
dadrought6
May 21, 2009 07:37 PM
crxh22a4
Mar 28, 2008 11:11 AM
turboH22Aakkord
Oct 5, 2007 01:31 PM
syclone
Oct 18, 2004 12:34 PM
zCivic
Jul 5, 2002 03:27 AM
