Brazing help!!!
Old Oct 31, 2006 | 12:18 PM
JDM_rolex's Avatar
Default Brazing help!!!
when i am brazing, the finished product has a whole bunch of holes on it..they are more like craters in it, there are a lot of these craters, i think its called porosity. how can i reduce this? thanks!!!
Old Oct 31, 2006 | 12:47 PM
Bailhatch's Avatar
Default Re: Brazing help!!! (JDM_rolex)
clean metal and clean filler
Old Oct 31, 2006 | 02:59 PM
snoot_works's Avatar
I'll assume you're brazing carbon steel with low fuming bronze? Your joint needs to be clean (free of oil and mill scale as well, preferrably.)
Try using less heat.
Old Oct 31, 2006 | 07:16 PM
JDM_rolex's Avatar
Default Re: Brazing help!!! (snoot_works)
ok i tried that, i cleaned it very good, and used less heat, still happens to me..
Old Oct 31, 2006 | 07:31 PM
Bailhatch's Avatar
take a few pics for us.
Old Nov 1, 2006 | 06:54 AM
dfoxengr's Avatar
Default Re: Brazing help!!! (Bailhatch)
try the dip-type flux
Old Nov 1, 2006 | 08:12 AM
Yes, pics would help for sure.
Old Nov 1, 2006 | 08:25 AM
snoochtodanooch's Avatar
i don't think i've ever had brass get holes in it, even on really dirty stuff. Something sounds contaminated. What material are you welding and what rod are you using?
Old Nov 1, 2006 | 10:59 AM
jaydmcrx's Avatar
flood it with filler rod. The filler rod is going to act as a quenching mechanism as well as add structure the the metal. Don't go overkill obviously, but it worked for me.
Hanmin
Transmission & Drivetrain
Dec 26, 2008 11:44 AM
2point2
Welding / Fabrication
Jan 17, 2007 06:02 PM
self_made
26
Nov 20, 2006 01:06 PM
danielm3
16
Feb 18, 2006 02:15 PM
Hybridhonda561
Jun 5, 2002 10:38 AM
