Oil leaked out of head WHILE torquing down the head bolts. Problem?
SO, last night I torqued the headbolts down on my mini-me swap. I made sure all surfaces were clean, and I then placed the z6 head on the block. While I was lubing up the head bolts with the ARP-moly though, some oil in the head leaked out. There was enough to leak out of the front about an inch down the block.
My conern is; there is now oil in the head gasket between the head and the block.
Will this cause a problem? I am using ARP head studs and a Honda metal y8 3-layer headgasket.
Thanks in advance.
Thanks in advance.
1320vickers
Engine Machining & Assembly
Aug 3, 2018 12:30 PM
SQ is the SQUAD
Nov 15, 2007 11:25 AM
