mini me swap help!!!
Okay HT I did a mini me swap on my hatch '92 (d15b/z6) I had the head rresurfaced used cometic head gasket copper sprayed and torque down in 2 step sequence. But for some reason I keep overheating and my cool and is low I have no visible leaks and my oil is clear from coolant has anybody ever seen this problem please advise no bashing please
I never narc'd on nobody!
Re: mini me swap help!!!
First off, you don't use copper spray on Honda head gaskets. Second off, did you re-use your old head bolts? You shouldn't do that on a Honda either. You said you had the head resurfaced, but did you check the block for warpage? You should always check the head and the block.
Do a block test to confirm, but you probably installed the head incorrectly.
If you loved me, you'd all sell me your magic cards to me today
vaypourus
10-31-2006 11:08 AM
simplypinoyy
05-20-2004 11:31 PM
