what ecu do i need?
Old Oct 30, 2006 | 08:50 PM
smokin403's Avatar
Default what ecu do i need?
I have a 1994 civic ex, i bought it used, it has a d15b5 in it (what is that?) can't figure out what ecm to use with it. It has a p08-6 head on it, it has great compression, 195 across the board, but it's not smogging at all. It has the ex ecu in it. I'm thinking it's the ecu's fault. I keep getting map and 02 codes, but there both fine, i checked them in mt 95 integra and they work great, the o2's not even lazy.
anyone know where to find a correct ecu and which it is? the engine is v-tec 1.5l but no idea where it came from. the dude i get the car from said it was a jdm swap. But i can find no info on that block number
Thank's
Le Roy
Old Oct 30, 2006 | 09:54 PM
BlueIntegraBoy's Avatar
Default Re: what ecu do i need? (smokin403)
You sure it's not a D15B6?
1988-1991 Honda CRX HF
Displacement : 1493 cm3
Bore and Stroke : 75 mm X 84.5 mm
Compression : 9.1:1
Power : 62 hp(88-89) 70 hp(90-91)@ 4500 & 83 ft·lbf @ 3000 rpm
Valvetrain : SOHC (2 valves per cylinder)
Fuel Control : OBD-0 MPFI
ECU: PM8
Old Oct 31, 2006 | 05:18 AM
smokin403's Avatar
Default Re: what ecu do i need? (BlueIntegraBoy)
without a doubt, it's stamped plain as day on the block, and the other # was stamped into the head. my local smog guy couldn't even figure out what it was. I wonder if it's a euro version or somthing?? he said he got it off e-bay. so you never know.
nicolaselias
Sep 7, 2010 05:41 PM
zccivicex
Honda Civic (2001 - 2005)
20
Sep 29, 2009 08:14 AM
serious
Mar 21, 2003 09:43 AM
