HELP:Oil Pump+Oil Light+Whine+No Vtec =????
ok so ive been having this problem for a while but ive been putting it off for a few months mostly cuz i dont drive my car any more. its a 99 si gone threw a couple motors. this one is a b16 pretty stock besides a CAI. now i had a oil pump that i threw on there. when i was putting the motor together.
Problem: When i first start the car in the morning or after its been sitting for a while the oil light comes on for about 10-12 sec. once the light goes OFF. i hear a supercharger like whine. Once the car is warmed up the noise goes away.
also my vtec isnt working.
now my question is how likly is it that this is because of my oil pump?
and no i havnt checked my oil pressure yet..which i should but ill get to it...
Thanks in advance.
OH also is there a way to find out what a CEL code would be if the CEL clears after you turn the car off then on agian.
Thanks in advance.
First thing, check your oil pressure. And if the CEL goes away every time then your going to have to be ready to pull the code before you turn your car off.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock_honda_coupe »</TD></TR><TR><TD CLASS="quote">First thing, check your oil pressure. And if the CEL goes away every time then your going to have to be ready to pull the code before you turn your car off.</TD></TR></TABLE>
how do i pull the code with the car on?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hitvtecgetloud09 »</TD></TR><TR><TD CLASS="quote">
how do i pull the code with the car on?</TD></TR></TABLE>
You plug a scan tool into the connector under the dash near the steering wheel, and pull the code out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">change out the oil pump. you dont have any oil pressure</TD></TR></TABLE>
is there a way of changing the pump with out taking the pan off?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hitvtecgetloud09 »</TD></TR><TR><TD CLASS="quote">is there a way of changing the pump with out taking the pan off?
Not without damaging something. Do it right or dont do it at all this isnt something that you should play around with like you already have. That 10-12 seconds of the oil light is bad enough.
Did you change the pick up with the new oil pump?
</TD></TR></TABLE>Not without damaging something. Do it right or dont do it at all this isnt something that you should play around with like you already have. That 10-12 seconds of the oil light is bad enough.
Londo2557
Nov 28, 2016 07:27 AM
311
Oct 23, 2002 08:20 AM
