Does this price sound right for a head-gasket?
Old Oct 30, 2006 | 02:42 PM
Clubhead's Avatar
Default Does this price sound right for a head-gasket?
Hey everyone,
My Del Sol Shas 187k on it and it just recently started overheating...So i checked the coolant only to find that there is nothing left.....Filled it up and checked the lines....nothing! So basically this happened again so i took it to the shop to get a pressure check of the system (I am @ college so i don't have the tools or location to work on it myself )
The Shop here told me its an internal leak in the head gasket.....so basically here is the run down from the shop to fix everything and replace a few things along the way that i would only assume need to be replaced to? (all prices include installation and parts)
Head Gasket kit - $600
Water Pump - $150
Coolant check - $ 30
Timing Belt - $ 122
Machine Shop $ 40
Total $970 (w/ tax and all the numbers i didn't round off)
Does this sounds right? Is it worth doing to a car with 187K...I mean i know Honda's will last thats why I might need to just get this work done....Is all the other stuff nessary or are they just trying to soak me.....I heard this is an honest shop.
I would love some HT guys opinions! Just to put my stressed out mind at ease
Thanks!
Old Oct 30, 2006 | 02:48 PM
92ehatch's Avatar
Default Re: Does this price sound right for a head-gasket? (Clubhead)
headgasket kit 600?
is that just the headgasket and labor?
i would go buy the parts you need and see how much labor would be to install them
or are those prices with labor too?
Old Oct 30, 2006 | 04:09 PM
Paxil4x4's Avatar
Default Re: Does this price sound right for a head-gasket? (92ehatch)
Are they even going to machine the head?
Old Oct 30, 2006 | 04:24 PM
e jay one's Avatar
Default Re: Does this price sound right for a head-gasket? (Paxil4x4)
make sure the lube you up before they rape you. actually since you dont know how to do it it is going to be expensive. but assuming its a d15b7 or even a z6 you could buy like 3 motors for that price. i bought a full ls swap for less then that.
Old Oct 30, 2006 | 05:00 PM
Clubhead's Avatar
Default Re: Does this price sound right for a head-gasket? (e jay one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch &raquo;</TD></TR><TR><TD CLASS="quote">headgasket kit 600?
or are those prices with labor too?</TD></TR></TABLE>
Everything listed is including labor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paxil4x4 &raquo;</TD></TR><TR><TD CLASS="quote">Are they even going to machine the head? </TD></TR></TABLE>
They just said after they take it off their going to give it to a machine shop to test for cracks and warping and whatever they do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one &raquo;</TD></TR><TR><TD CLASS="quote">make sure the lube you up before they rape you. actually since you dont know how to do it it is going to be expensive. but assuming its a d15b7 or even a z6 you could buy like 3 motors for that price. i bought a full ls swap for less then that.</TD></TR></TABLE>
No kidding....My last car was a cavalier and i took off the head to swap it out....so i am assuming this wouldn't be to different....but like i said i can't do the work here with no tools and just a campus public parking lot.
Would you get it fixed or just get a new motor to swap in it?
thanks for the help so far
Old Oct 30, 2006 | 05:01 PM
Clubhead's Avatar
btw, its a D15b7
Old Oct 30, 2006 | 05:08 PM
Everyones Hero's Avatar
That sounds normal.
Personally I'd go to the local hardware store/mall & pickup a ratchet, a set of sockets, wrenches & do that **** myself in the parking lot.
When was the last time you had a new timing belt/water pump installed?
Old Oct 30, 2006 | 05:15 PM
Clubhead's Avatar
Default Re: Does this price sound right for a head-gasket? (Everyones Hero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Everyones Hero &raquo;</TD></TR><TR><TD CLASS="quote">That sounds normal.
When was the last time you had a new timing belt/water pump installed?</TD></TR></TABLE>
Me and my roomie were just talkin about doing the work in our housing complex......I just can't justify spending that much money on a base model Sol.....$900?
See the thing is I bought the car from a private party who did a bunch of manintence work before i got it....and i believe one of them was timing belt....So i could probably "X" that out....and i dunno why i would need a new water pump
Old Oct 30, 2006 | 05:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clubhead &raquo;</TD></TR><TR><TD CLASS="quote">Me and my roomie were just talkin about doing the work in our housing complex......I just can't justify spending that much money on a base model Sol.....$900?
See the thing is I bought the car from a private party who did a bunch of manintence work before i got it....and i believe one of them was timing belt....So i could probably "X" that out....and i dunno why i would need a new water pump </TD></TR></TABLE>
Water belt & T-belt usually get replaced at the same time because if one is off you have easy access to the other.
expletive it, pull the ******* head off, take it to a machine shop, have them mill it, and then throw the SOB back on.
Old Oct 30, 2006 | 05:45 PM
Skunk.Werks's Avatar
And rent a torque wrench from autozone, get your money back when you return the rental.
Old Oct 30, 2006 | 05:59 PM
Clubhead's Avatar
expletive it, pull the ******* head off, take it to a machine shop, have them mill it, and then throw the SOB back on.</TD></TR></TABLE>
Alright we are gonna just do it after class.....Machine shop is just down the road according to the phone book...so done deal...thanks for the input
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk.Werks &raquo;</TD></TR><TR><TD CLASS="quote">And rent a torque wrench from autozone, get your money back when you return the rental.</TD></TR></TABLE>
We were just talkin about renting the tools we don't have (the non-basics)....So hopefully between the 2 of us we can get this taken care of in one day and a few cases of beer....Hopefully we don't have to much and then forget how to put the car back together
Thanks for all the positive input
Old Oct 30, 2006 | 06:32 PM
Steven.'s Avatar
head gasket is 37 on ebay and my d15b7 is burnin oil maybe coolant
sammyb2120
Honda Civic (2001 - 2005)
Jul 20, 2015 07:04 PM
95ludeVTEC
Nov 10, 2010 08:15 PM
1994rsa
Mar 20, 2009 12:45 PM
Freedumb1105
Mar 16, 2008 12:47 AM
log1c
May 14, 2006 01:02 AM
