coolant problem
Old May 13, 2006 | 06:47 PM
log1c's Avatar
Default coolant problem
i have a problem where the thermostat goes from C to H when i am braking or when my car is idle, but when i gas the car it goes back to C. i checked the reservoir the coolant is gone but its not leaking. i went to the mechanic and they said there was no leak but there is something wrong with the engine. he said it could be the head gasket, water pump or timing belt.
they said it would cost $495 for parts and labor to fix it.
is that a good price or is there any place i can get the parts for cheaper.
Old May 13, 2006 | 07:02 PM
__oversea's Avatar
Default Re: coolant problem (log1c)
dont do anything unless your sure or they are sure what the problem is.
take off thermostat and check its working, do a compression test, could be air bubbles in the line, flash and refill.
Old May 14, 2006 | 01:02 AM
all-mtr-teg's Avatar
Default Re: coolant problem (Last For One)
Why are you changing head gasket? is is leaking coolant or is the head warped?
jermie_jrmz
Honda Civic (2001 - 2005)
12
Dec 27, 2009 01:26 AM
StupidSlowRSX
Dec 17, 2007 07:00 PM
turbols99
Feb 5, 2007 07:28 PM
ALMXDUPINTEGRA
May 11, 2005 11:05 AM
prendi
Aug 22, 2003 02:10 PM
