VTEC in my 99 LX
Old Oct 30, 2006 | 02:23 PM
Playa_FL's Avatar
Default VTEC in my 99 LX
When the Vtec kicks in on a 99 LX, can you hear it or is it very slight? Is it like when vtec kicks in on a b series engine? I'm not sure if my vtec is working, it threw a code for vtec malfunction, but the CEL turned itself out. Thanks in advance.
Old Oct 30, 2006 | 02:33 PM
ujhonda's Avatar
Default Re: VTEC in my 99 LX (Playa_FL)
Ooh yes; I had the same problem, but I fixed it
1st check your oil level - if it's ok
now check your VTEC solenoid - even it's good - need some clean up
Old Oct 30, 2006 | 02:36 PM
Playa_FL's Avatar
Default Re: VTEC in my 99 LX (ujhonda)
where is the solenoid, and how do i check it? what do you mean by clean up? and when vtec kicks in, can you feel and hear it?
Old Oct 30, 2006 | 02:45 PM
ujhonda's Avatar
if your VTEC not working, you'll know that - its feels s*it when you drive
it is behind the valve cover, order to clean you have to remove it
also check the VTEC solenoid with a multimeter
you must have your Technical manual handy
Old Oct 30, 2006 | 03:28 PM
H2290's Avatar
Also even when you do hit VTEC in the F23 you probably won't notice.
Old Oct 30, 2006 | 03:35 PM
Playa_FL's Avatar
Default Re: VTEC in my 99 LX (H2290)
ok just making sure. I finally got my haynes manual in today, i'll be pulling the solenoid to make sure its not clogged. How come the VTEC is different on the B-series motors? When it hits on those, it sounds like all hell is breaking loose.
Old Oct 30, 2006 | 05:24 PM
philadd's Avatar
There are different types of VTEC systems, and then you have some motors that are DOHC and some that are SOHC. B-series VTEC systems were designed with performance in mind, while Accord F-series VTEC systems were designed with economy/efficiency in mind, with a little power mixed in. B-series VTEC is a part of both the intake and exhaust cams, while Accord F-series VTEC is only a part of the intake cam. B-series VTEC causes more valve lift and duration change than Accord F-series VTEC.
If you want to make it more complicated, when can start talking about i-VTEC and VTEC-e...
Old Oct 31, 2006 | 12:08 PM
H2290's Avatar
Default Re: VTEC in my 99 LX (philadd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd &raquo;</TD></TR><TR><TD CLASS="quote">There are different types of VTEC systems, and then you have some motors that are DOHC and some that are SOHC. B-series VTEC systems were designed with performance in mind, while Accord F-series VTEC systems were designed with economy/efficiency in mind, with a little power mixed in. B-series VTEC is a part of both the intake and exhaust cams, while Accord F-series VTEC is only a part of the intake cam. B-series VTEC causes more valve lift and duration change than Accord F-series VTEC.
If you want to make it more complicated, when can start talking about i-VTEC and VTEC-e...</TD></TR></TABLE>
Please, not another DOHC VTEC vs SOHC VTEC vs DOHC i-VTEC vs SOHC i-VTEC vs VTEC-e vs VVT-i vs iForce vs Hemi vs Zetec vs VANOS vs VVT vs . . .
THREAD.
Old Oct 31, 2006 | 03:15 PM
philadd's Avatar
hehe... Trust me, I don't want it to turn that way either.
Old Oct 31, 2006 | 09:53 PM
Patman's Avatar
SOHC Vtec still sounds pretty ballistic to me, especially for a 4 banger it gets loud as hell.
Stevemyster
May 16, 2011 12:45 PM
1sgranger75
Honda Civic (2001 - 2005)
Sep 27, 2010 08:59 PM
swappedcivic
Dec 14, 2004 08:30 AM
goforbroke
Feb 24, 2003 04:47 PM
