Question on Wheel bearings
Old Oct 30, 2006 | 09:53 AM
itr1244's Avatar
Default Question on Wheel bearings
appearently.. i can get the front wheel bearings alone..not the whole hub assembly..
but for the rear ones.. it seems like i have to ge the whole hub?
http://www.barancoacuraparts.c...ch=no
Old Oct 30, 2006 | 10:04 AM
ylfotevoli's Avatar
Default Re: Question on Wheel bearings (itr1244)
Looks like it from the illustration. You should call that company, if they won't do it, let me know. A guy at Ac of Escondito broke some stuff down for me...
Not tryin to pirate your thread, but maybe you can help me. Ever since I bought my car, there is a harmonic metallic noise in sync with wheel speed. It sounds a little wobbly, and when I turn the wheel it changes harmonics (still at wheel speed). Can't really describe it well, but you think it might be the bearings? Thanks...
Old Oct 30, 2006 | 10:39 AM
walker111's Avatar
Default Re: Question on Wheel bearings (wildcarditr102)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wildcarditr102 &raquo;</TD></TR><TR><TD CLASS="quote">Looks like it from the illustration. You should call that company, if they won't do it, let me know. A guy at Ac of Escondito broke some stuff down for me...
Not tryin to pirate your thread, but maybe you can help me. Ever since I bought my car, there is a harmonic metallic noise in sync with wheel speed. It sounds a little wobbly, and when I turn the wheel it changes harmonics (still at wheel speed). Can't really describe it well, but you think it might be the bearings? Thanks...</TD></TR></TABLE>
Yes
Old Oct 30, 2006 | 01:04 PM
AllMotr's Avatar
As far as I've seen (and I've seen a lot) all rear bearing come in the hub and
bearing style.
Old Oct 30, 2006 | 01:07 PM
AllMotr's Avatar
Default Re: Question on Wheel bearings (walker111)
Common problem for Acura Integra wheel bearing from 94-01. Replace a ton of them when I worked for Acura...now working for Honda
To answer your question when you load the car up either left or right, usually the side that gets louder when you load that bearing is the faulty bearing. I said usually. You can lift the *** end up and spin the wheels and put your hand on the
lower control arms and feel for any roughness...if you do that is the faulty bearing.
Old Oct 30, 2006 | 03:10 PM
uNF$@#!'s Avatar
Default Re: Question on Wheel bearings (AllMotr)
you can not purchase the rear bearings alone. replace the entire hub.
Old Oct 30, 2006 | 03:22 PM
Splat's Avatar
Collector-o-Guns and Drinker
Side note since we're talking about wheel bearings...
In general, play when the wheel is rocked with your hands as 12 and 6 is wheel bearing, no? Side-to-side (9 and 3) is fine.
Old Oct 30, 2006 | 07:22 PM
crxgator's Avatar
replacing rear wheel bearings is also a lot easier compared to the front...takes like 30 mins a side...
Old Oct 30, 2006 | 08:39 PM
ylfotevoli's Avatar
Default Re: Question on Wheel bearings (crxgator)
My noise is coming from the front
woodenchef
Jun 16, 2013 10:31 AM
nipcup101
Jul 20, 2009 05:17 PM
ZexyAccord
Honda Motorcycles
May 31, 2007 05:27 PM
.I.Need.Money.
13
Dec 31, 2006 09:47 AM
ncsuteg
11
Jul 13, 2003 11:58 AM
