HELP!!!!!! check clutch fluid!!!
Old Oct 30, 2006 | 07:19 AM
BiGcAmBoDiAnSaUsAgE's Avatar
Default HELP!!!!!! check clutch fluid!!!
how do u change ur clutch fluid when ur runnin low!!!!???
Old Oct 30, 2006 | 07:31 AM
-Gary-'s Avatar
Default Re: HELP!!!!!! check clutch fluid!!! (BiGcAmBoDiAnSaUsAgE)
Put more in....
It's next to your master cyl for your brakes.
Old Oct 30, 2006 | 08:08 AM
Syndacate's Avatar
Default Re: HELP!!!!!! check clutch fluid!!! (-Gary-)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -Gary- &raquo;</TD></TR><TR><TD CLASS="quote">Put more in....
It's next to your master cyl for your brakes.</TD></TR></TABLE>
I think he's aiming more at...how do you check it...like to see what the level is...
Old Oct 30, 2006 | 08:27 AM
rb26s14's Avatar
Default Re: HELP!!!!!! check clutch fluid!!! (Syndacate)
Just feel the clutch, u don't feel any pressure then put more in. I usually just fill it up.
Old Oct 30, 2006 | 08:29 AM
NJcoupe's Avatar
Default Re: HELP!!!!!! check clutch fluid!!! (rb26s14)
If theres none in there, and you just add more, you have to bleed the clutch again.
Old Oct 30, 2006 | 11:24 AM
Default Re: HELP!!!!!! check clutch fluid!!! (dxcoupe.)
how do u bleed it? hydro!!!!!
Old Oct 30, 2006 | 11:55 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BiGcAmBoDiAnSaUsAgE &raquo;</TD></TR><TR><TD CLASS="quote">how do u bleed it? hydro!!!!! </TD></TR></TABLE>
Open up the valve, it is by the tranny. Have someone pump the clutch pedal like 3 times and hold the pedal down on the last one. Close the valve and repeat the process until all air bubbles are out.
The bleeder screw is #1 in the diagram:
Old Oct 30, 2006 | 01:21 PM
rice a roni's Avatar
um...i dont think there is any fluid in your clutch buddy.
Old Oct 30, 2006 | 08:41 PM
Default Re: HELP!!!!!! check clutch fluid!!! (EL Vap133)
thanx man!!!!!!!! helpful info!!!!!!!
Old Oct 30, 2006 | 08:48 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BiGcAmBoDiAnSaUsAgE &raquo;</TD></TR><TR><TD CLASS="quote">thanx man!!!!!!!! helpful info!!!!!!!</TD></TR></TABLE>
No problem, unless there is a leak this should take care of the problem.
Old Oct 30, 2006 | 08:54 PM
Everyones Hero's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">Open up the valve, it is by the tranny. Have someone pump the clutch pedal like 3 times and hold the pedal down on the last one. Close the valve and repeat the process until all air bubbles are out. </TD></TR></TABLE>
I thought it was "push push push hold open close release"
Won't having the bleeder open while you're pumping cause it to suck air back into the line?
Old Oct 30, 2006 | 09:02 PM
EL Vap133's Avatar
Default Re: HELP!!!!!! check clutch fluid!!! (Everyones Hero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Everyones Hero &raquo;</TD></TR><TR><TD CLASS="quote">
Won't having the bleeder open while you're pumping cause it to suck air back into the line?</TD></TR></TABLE>
You mean push the pedal all the way down, then close all on one pump?
I did it the way I posted and it worked for me, no air in the line and the clutch works fine.
Old Oct 30, 2006 | 09:04 PM
pump the clutch 3 times, loosin the bolt than tightin it...repeat it til u see like a bubble!!!!!!!!!rite?
buzlink
Oct 22, 2007 05:25 PM
popo bawa
Jul 17, 2006 09:57 AM
redej878
20
Jul 13, 2006 06:03 AM
KloC 95 EG
Mar 13, 2006 09:18 PM
Tomatohatch
May 10, 2004 09:19 PM
