put ex coupe doors with power windows want to make them work in my dx do i need harness from the doo
OR they already have wiring in the car and i just plug them or i need to buy a new fuse box that has the harnees from the inside the cAr to the door?
The hardest part of this project is aquiring the parts. After that it is plug and play. And you can make your own floor cable but I went to the jyard and pulled all the wires I needed. GL.
i did this
i purchased a 94 civic ex 2 door
gutted the car and every wire including the main harness all fuse boxes under the hood and dash
removed every wire in my cx
installed wires and fuse boxes from ex into cx
i installed a d15b so i didnt have to wire for vtec cause the ex has it
the harness for the rear lights is different form the ex so you will have to re pin the connection its not plug and play but everything else was
i added power windows locks cruise tilt wheel ex tweeters intermedit wipers
i will never do this again way to much work but i love having it done the right was not one wire was cut so everything looks and works like factory
if someone shows me how to post pictures i have many
This would be the way to go but he is right, its work.
You dont have to do everything he did tho.
willie
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by williejohnson »</TD></TR><TR><TD CLASS="quote">i did this
if someone shows me how to post pictures i have many </TD></TR></TABLE>
willie<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by williejohnson »</TD></TR><TR><TD CLASS="quote">i did this
You do not need the floor harness. You change 2 wires for the rear speakers. You need the main harness, under the dash, the inner door harness, and the components inside the door. I did it to my dx.
tigueremalo
Apr 6, 2007 09:39 PM
crazycivichatch
11
Sep 22, 2006 08:27 PM
Eibach95Civic
Jul 17, 2003 08:49 AM
