DPFI to MPFI problem
Old Oct 29, 2006 | 06:16 PM
stivic's Avatar
Default DPFI to MPFI problem
OK I finally finished wiring up today and after triple checking all wiring to make sure it's all right since the first article I read on how-to was completely opposite of what needed to be done. I can only think it maybe an injector problem they have been sitting around for about a year or longer . I get no CELs it starts up fine everytime just about but gets barely any throttle response all it does is bog down when I press the gas but only bogs in the lower RPMs any suggestions? I also checked all grounds they seem to check out fine
Old Oct 31, 2006 | 01:04 AM
Redline130's Avatar
Default Re: DPFI to MPFI problem (stivic)
Did you switch around the two outer wires on the TPS sensor connector?
PNK SLP
15
Aug 17, 2010 11:30 AM
bam_89
Feb 3, 2010 02:55 PM
Maxximtl
Apr 21, 2006 08:46 AM
caspers_hatch
Nov 5, 2005 05:19 PM
