Im ready to Are these the right parts for LS/Vtec oil line?
Im going to order as soon as I get a "ok", or "
" from someone who has put a oil line kit together before.
Im not going stright from the oil sending unit hole to the head, Im taking a SS line from the oil sending unit hole to the fire wall. The tee will be hooked to that SS line on the fire wall. The top of the tee will be for the oil sending unit, and the other side will be going to the head.
Here are the parts I came uip with.
(1)20" legnth of braided SS line w/4AN female hose ends (from the engine to the fire wall)
(1)24" legnth of braided SS line w/4AN female hose ends hose ends (from the tee to the head)
(1)1/8" NPT tee
(4)1/8" NPT to 4AN fittings (1 off the block, 2 in the tee, 1 off of the head)
(1)3/8" NPT to 1/8" NPT (replaces the plug on the head, and alows to use 1/8"NPT to 4AN fitting)
Does it sound like I have the right parts? I need to know for sure cause I am ordering this stuff today. I don't want it to get here and find out its the wrong stuff.
[Modified by InfamousRS, 11:54 AM 5/6/2002]
" from someone who has put a oil line kit together before. Im not going stright from the oil sending unit hole to the head, Im taking a SS line from the oil sending unit hole to the fire wall. The tee will be hooked to that SS line on the fire wall. The top of the tee will be for the oil sending unit, and the other side will be going to the head.
(1)1/8" NPT tee
according to the site above, there is a 3/8" NPT to -4AN fitting
20" ss line seems a little long to go from the block to firewall
also, where is the 1/8 npt plug on your list to plug the vtec oil supply on the bottom of the head? this hole will need to be tapped
sorry i dont have my list in front of me, but i t'd off the block so my list would be a tad different
[Modified by Jeff C, 7:54 AM 5/7/2002]
