no more A-pipe rattle!!
Old May 6, 2002 | 09:43 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default no more A-pipe rattle!!
I finally got my A-pipe/downpipe fixed this past weekend. I took it to a muffler shop that my friend recommended to me and told them about my problem. Although they tried messing around w/ heat shields and stuff even though I told them that was not the problem, they finally decided to mess w/ the downpipe. They blasted a 1/2" dia. hole into the side of both intermediate pipes (before the collector at the flange before the cat), stuck the welder in there and I guess it welded the inner pipe to the outer pipe, so it is finally quiet! And they only charged me $20.
Old May 6, 2002 | 09:59 AM
Rory Breaker's Avatar
Default Re: no more A-pipe rattle!! (PatrickGSR94)
What did I tell ya?
Old May 6, 2002 | 10:06 AM
TGUNNER's Avatar
Default Re: no more A-pipe rattle!! (newgsrdriver)
I wonder if I could do the same with my POS DC header... that thing makes so much noise when i let of the gas.. commin down between like 6500-4000 rpm
Old May 6, 2002 | 10:19 AM
obsidianG35's Avatar
Had the same problem on both my tegs.
LS-heat sheild
GSR- Allitle more difficult to find out. but it was A/B pipe, and it went away when I got my DC headers.
If you need to distinguish between the two:
Heatshield- Rattles at idle, any rpm
A/B Pipe- Rattles only at 3000-3500 Rpm.
Honda said this was a common problem with the Tegs, they have replacement packages ready. Might as well go with a new aftermarket header though right?
Old May 6, 2002 | 10:22 AM
Default Re: no more A-pipe rattle!! (r4integra)
Just to clear a couple things up, the heat shields can rattle at certain RPMs only as well. And it is the A-pipe that has the problem. A header or the above fix will solve the problem.
TGunner - You sure the header bracket is bolted on properly/at all? Your problem is something different, sounds like a loose bolt.
Old May 6, 2002 | 10:29 AM
TGUNNER's Avatar
Yeah that thing drives me crazy.. ive checked it a million times... the vibration is comming from inside the header... So i figured a weld inside mayhave busted.. Im so aggrivated im thinkin of putting on my stock exhaust manifold...
Old May 6, 2002 | 11:41 AM
Community Builder
Default Re: no more A-pipe rattle!! (TGUNNER)
Well aftermarket headers are not double wall as far I know, like the GS-R manifold/downpipe is. I can't afford a header right now, so a $20 repair to the stock parts fits the bill very nicely.
Old May 6, 2002 | 11:44 AM
TGUNNER's Avatar
TIP: When you do get a header dont cheap out and go DC like I did... GO COMPTECH!!!
Old May 6, 2002 | 11:57 AM
Sorry, thats what I meant. Any random RPM, but if its between 3-3.5k, its most likely to be the B pipe. Thanks for clearing that up.
D
Cap'N Chronic
18
Sep 10, 2012 08:36 PM
vtec2K9
Sep 7, 2008 04:58 PM
IggDawg
Nov 12, 2003 07:31 PM
mickey513
May 23, 2002 04:40 AM
93LSivic
Apr 16, 2002 10:09 AM
