turbo help
Old Oct 29, 2006 | 06:54 AM
h22delsol's Avatar
Default turbo help
ok guys i got a t25 i droped ni my d16z6 in my del sol ever thing is hooked up and for some reason ino boost is gettin to my engine i dont know if its because i have all my vaccum line spliced into one line and it has vaccum but i got no boost reaching the engine
Old Oct 29, 2006 | 06:57 AM
jpnucrx's Avatar
Default Re: turbo help (h22delsol)
English please!!
And use some periods and commas.
You might want to check all your vaccum lines first. Is the turbo spooling?
Old Oct 29, 2006 | 07:07 AM
h22delsol's Avatar
Default Re: turbo help (jpnucrx)
sorry, yes the turbo is spolling. what to do the check my vaccum lines. pm if you want
Old Oct 29, 2006 | 08:41 AM
Schister66's Avatar
Man U FTW
this is a good one for the FI section....
is your wastegate stuck, is the BOV stuck open, are all of your vaccuum lines hooked up correctly, are all of the couplers tight??
Those are a few things you could check...
Old Oct 29, 2006 | 07:18 PM
VtecnTurbo's Avatar
Default Re: (Schister66)
does your boost gauge read vaccum when the car is at idle? should be right around 20
Old Oct 30, 2006 | 03:40 AM
h22delsol's Avatar
Default Re: (VtecnTurbo)
yeah it reads vaccum but it dont jump like it should when you give it gas
Old Oct 30, 2006 | 04:52 AM
Everyones Hero's Avatar
Default Re: (h22delsol)
What did you use for charge pipes? A kit or did you do it yourself?
Any chance of bad welds/couplers with holes in them?
If everything is off of the same vacuum source there is a possibility that your BOV is not closing when you go WOT because the vacuum source may not be strong enough to close it.
Old Oct 30, 2006 | 06:10 AM
HiProfile's Avatar
Default Re: (Everyones Hero)
I'd check to see if your charge pipes actually lead from the compressor outlet to the throttle body 1st. OR that you have them for that matter. Forgive me if you actually have theses, theres is just always that one 'special' guy each month that slaps a snail on - naked - clueless how it works & makes power.
Sounds like a severe leak otherwise, your vac gauge should be connected after the throttle body.
Maple50175
Jul 27, 2008 04:07 PM
craig88crx
Apr 20, 2008 02:30 PM
almostjdmeg
Mar 10, 2008 01:00 PM
IronOutlawz
Aug 9, 2005 11:51 AM
crucial si
May 31, 2003 08:46 PM
