new motor deosnt start
Old Oct 28, 2006 | 08:44 PM
deryck324's Avatar
Default new motor deosnt start
so i have a 92 eg hatch with a obd1 b16 in it and a p30 as the ecu . it didnt come with a harness so vaporboy13 made me one with obd1 injector clips on an obd2 harness . for some reason it wont start ......please help
Old Oct 28, 2006 | 08:54 PM
fmrprojects's Avatar
Default Re: new motor deosnt start (deryck324)
make sure you have all the grounds connected and the ground on the theromstat housing where the thermostat is at
Old Oct 28, 2006 | 08:55 PM
deryck324's Avatar
Default Re: new motor deosnt start (fmrprojects)
the ground that coumes out of the harness?
Old Oct 28, 2006 | 08:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deryck324 &raquo;</TD></TR><TR><TD CLASS="quote">the ground that coumes out of the harness?</TD></TR></TABLE>
yeah. its suppose to be on with a 10mm bolt to the housing. its near the fan switch on the t-stat housing
Old Oct 28, 2006 | 09:02 PM
ek_chris's Avatar
does it crank over? or not even crank? Check the voltage of your battery, check fuses, grounds (t-sat housing, tranny to chassis), check the connection to the starter, etc.
Old Oct 28, 2006 | 09:06 PM
deryck324's Avatar
Default Re: (ek_chris)
it carnks it just wont start , i added 1 more ground but havnt tryed it out yet , as far as voltage i had it conected to my moms car witch was running
i dont think its getting spark , but i dont knopw what would cause that since i checked all the parts off the dizzy and its getting juice its just not putting any out
Old Oct 28, 2006 | 09:42 PM
John M's Avatar
Default Re: (deryck324)
try it now with the ground u added
Old Oct 28, 2006 | 11:43 PM
93(Civic)EG6's Avatar
is your fuel pump turning on? Why are you using anything that is obdII? just use a d16z6 engine harness, its all plug n play besides for the knock which u can hardwire or chip after
Old Oct 29, 2006 | 11:44 AM
deryck324's Avatar
Default Re: new motor deosnt start (93(Civic)EG6)
yeh the fuel pump is turning on , well im buddy had a harness lying around and i had a jdm obd1 harness lying around so we made a haness that should work .
Old Oct 31, 2006 | 03:31 AM
why would you make a harness that should work because then you would have to go back and double check it works with a voltmeter. Is that really worth the hassle and time over a $100?? Just get a obd1 usdm vtec harness, best bet a ex si 92-95. I have one if you want it but i was gonna end up listing it on ebay either way.
Old Oct 31, 2006 | 03:33 AM
Also if you have any questions regarding this swap just let me know because I have already finished a swap like this!
Old Oct 31, 2006 | 10:06 AM
deryck324's Avatar
well i baught a harness and he posted it as a obd1 uncut gsr harness well its not what he said so now im down a creak without a paddal
Modified by deryck324 at 2:58 AM 11/1/2006
Old Oct 31, 2006 | 10:07 AM
deryck324's Avatar
i checked today and im getting spark
Old Nov 1, 2006 | 05:29 PM
since your getting spark and most likely getting air from the Throttle Body, i just have a feeling something is wrong with your fuel and how it is getting to the engine(which it probably isn't), to prove this right, buy some starting fluid and spray it into the throttle body and have someone else start the car and if it works then you know its a fuel problem.
Old Nov 1, 2006 | 06:05 PM
w0ng_sta's Avatar
Default Re: (99d16)
are u sure ur getting spark.. in the right order?.. maybe crossed some wires when making ur harness?
ldelgadol
Jan 21, 2016 09:19 AM
hellalaaag
May 5, 2014 12:38 AM
lvlistchif
Feb 4, 2011 08:03 AM
bara6075
Aug 22, 2007 04:25 PM
deryck324
Nov 2, 2006 08:22 AM
