tapping valves
Old Oct 28, 2006 | 03:55 PM
nub_pwn's Avatar
Default tapping valves
well theres a tapping sound i can hear from my motor, ....is it roller or rocker? im wondering how hard is it to re-adjust my valves, oh ya i have a 95 GSR in my hatchback motor is bone stock
any help would be appreciated
Old Oct 28, 2006 | 09:55 PM
nub_pwn's Avatar
BUMPPPPPPPPPPPPPPPPPPPPPPPPP
Old Oct 28, 2006 | 10:22 PM
chrisw85's Avatar
if your valves are adjusted then it could just be the ticking from your injectors. it gets confused with the valvetrain sometimes and some injectors can get loud. also some motor oils tend to show more of the noise of the valvetrain then others.
Old Oct 28, 2006 | 10:26 PM
mv1luv's Avatar
idid my valves on my 98 EK with 120,000 miles on it last week.. such a diffrence ican barelyhear that the motor is on now. after you calibrate your valves and u still think u have excessive noise i used a old skoolmethod .. a short hose to my ear and the other end to the valve cover to narrow down which valve needed more adjustment.
Old Oct 28, 2006 | 11:34 PM
Loi-Tech's Avatar
Default Re: tapping valves (nub_pwn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nub_pwn &raquo;</TD></TR><TR><TD CLASS="quote">well theres a tapping sound i can hear from my motor, ....is it roller or rocker? im wondering how hard is it to re-adjust my valves, oh ya i have a 95 GSR in my hatchback motor is bone stock
any help would be appreciated</TD></TR></TABLE>
<U>valve lash clearance specs for gsr motor</U>
intake valves .006
exhaust valves .007
the manual says .006-.007 for intake and .007-.008 for exhaust. but i always adjust it to be on the tight side.
Old Oct 28, 2006 | 11:43 PM
9200RPM's Avatar
Default Re: tapping valves (Loi-Tech)
adjust the valves, and if the noise is still there or comes back after a week you might need to change your lost motion assemblies. I had that problem with my b16. I know gsr lma's are stronger, but dont rule it out especially since theres probably some milage on that motor.
Old Oct 30, 2006 | 06:17 PM
B20inDCinLBC's Avatar
how can u tell if it is the lma?
Old Oct 30, 2006 | 06:19 PM
Syndacate's Avatar
Default Re: (mv1luv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mv1luv &raquo;</TD></TR><TR><TD CLASS="quote">idid my valves on my 98 EK with 120,000 miles on it last week.. such a diffrence ican barelyhear that the motor is on now. after you calibrate your valves and u still think u have excessive noise i used a old skoolmethod .. a short hose to my ear and the other end to the valve cover to narrow down which valve needed more adjustment. </TD></TR></TABLE>
Stethoscope works better.
VTECcnIT
Nov 7, 2005 01:17 AM
spankey167
23
Jan 12, 2005 11:13 PM
imonx850
Nov 2, 2004 10:53 PM
BulliztyK
Aug 15, 2003 12:45 AM
B18C1 '96 Coupe
Dec 30, 2002 09:33 AM
