clutch slip...
my clutch isnt even a year old yet, and it slips going into second and fourth at high rpm, like 7200. its on a d16y8 with i/h/e and stage 2 cam and valve springs. its an oem replacement clutch. could this be anything besides the clutch sucks?
its a daikin/exedy stock replacement. i mean i am a spirited driver but not some nutcase racing through the streets. yes it has been on the drag strip a few times, but i dont think it would already be worn.
thats weird, I have the same clutch, and it has been on my car for almost 2 years. I dont drive crazy, never been to the strip, but its slipped before at AutoX and stuff. Still works great for me.
its weird it grabs like a **** down shifting into thrid at 75 mph which puts it a few hundred below redline and then shifting up into 4th at 72-7300ish it slips...wtf
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic »</TD></TR><TR><TD CLASS="quote">expletive it, i wish i could win the lottery
so it couldnt be anything else?</TD></TR></TABLE>
come on now, its not that expensive. I think I got that same clutch on ebay for like $75, and installed it myself. No need to gamble your piggy bank away.
I am not saying it couldnt be anything else, but it sure sounds like a worn clutch the way you describe it.
it kinda sux it wore out so quick. a year isnt very long. i know its not expensive but i have an exhaust to fix too. and i just replaced the ehader because something broke off inside it, and a new 02 sensor
dirt or residue on your flywheel? That sounds a little silly to me. I doubt much would be able to stay between the clutch and flywheel and cause slippage. And if it wasnt happening before, why now? I am staying with worn clutch. I guess pulling the tranny off and looking would tell you whats up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic »</TD></TR><TR><TD CLASS="quote">grrr,, damn issues all popping up at once, i guess when i get my ISB replaced ill have em check the clutch</TD></TR></TABLE>
Holy ****, your paying someone to do that? That will put a dent in the wallet. How much are you getting it done for, if you dont mind me asking. I dont remember what I was quoted, but it was an insane amount that inspired me to bust open my tranny for the first time and do it myself.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imadigitalgod »</TD></TR><TR><TD CLASS="quote">i have a 99civic iwth a D16Y8 engine, has 114,000 miles on the clutch and it doesnt slip at all.
grandma driving FTW
that and good shifting
</TD></TR></TABLE>grandma driving FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sol2hatch »</TD></TR><TR><TD CLASS="quote">
grandma driving FTW
that and good shifting</TD></TR></TABLE>
yeah, the way i drive it will last a long time. i get on it a lot but the way i shift(even when getting on the gas) u cant really tell at all that i shifted at all when sitting in the car, its pretty smooth
grandma driving FTW
From: Swapin Motors,Tuckin Bays and Making Harness, CT, USfukenA
check your fluid in the resivoir...if it is low check the boot around your slave cylinder if you slide it of and it leaks oil its your slave and thats your problem....if not check inside the car under the dash if you see fluid leaking there, then its your clutch master...good luck
jdmstyleEJ6
12
May 9, 2010 04:13 PM
